boxygen
- Joined
- Sep 25, 2007
- Messages
- 251
- Location
- Southern Maine
- Tractor
- Mahindra 2415 TLB 1967 Holder AG3, articulated 4wd
Slab on grade can be very sucessful in cold climates,however, it is grossly misunderstood by most. Three conditions are needed for frost: cold temps, cohesive soil and water. If you are missing one of those, no frost can form. With proper reinforcing. Well graded soil and insulation can eliminate the correct conditions. Frost is formed by ice crystals forming below the surface when the right conditions are present. The ice crystals pull more moisture through the soil from below through capilary action. If the soil is right and moisture is present it will continue to draw up moisture and grow the ice crystals. Typically this is done at a rock, because a rock is a better conductor of cold than the surrounding soil, that is why rocks migrate up through the soil "magically". That being said, If you build your building on a pile of crushed stone with insulation under it and proper surface drainage, you will never have frost. The moisture cant be pulled up through the large voids in the crushed stone and the rigid insulation will keep the cold from migrating down into the soil. Rebar, fibermesh and steel mesh and control joints are all still a must. Detailing the insulation and drainage can be difficult and unique to each site.
That being said, to do a slab on grade the "right" way will most likely be more expensive than a post and wood floor building. There is more to a slab on grade than backing up the concrete truck and unloading the truck and leveling out if you want it to last. You can keep the building off the ground better with a post system than a slab on grade. A course of block is a must with a slab. I think the post system will also be faster to build. If you pour a slab, order the concrete mix air entrained if it will be exposed to freezing temperatures. I dont know what Concrete costs in Ohio but my grandfather lives in Ohio and he said it was expensive and that is why they do so many block foundations instead of poured concrete. You can get it here in Maine with Admixtures like mid range water reducer and fibermesh for about $85/ cubic yard.
