Concrete Floor
/ Concrete Floor #1
DaveRR
Northern NY State
I'm looking to pour a concrete floor in my basement, and just got my second cost estimate. I've never had any concrete work done before, so I thought maybe some of you could tell me how reasonable this estimate is.
The basement area is 430 sq ft. Part of the floor is already concrete (170 sq ft), and the rest is very coarse sand (native soil). I have already removed enough dirt to (more or less) level the unfinished floor a few inches lower than the finished floor. The foundation walls are dry stacked stone, and entrance to the basement is such that the concrete truck can back right up to the basement stairs. I'm not looking for anything fancy; just a concrete floor with a sump in the corner. Concrete prices here are $90-100 per yard.
The first estimate was $2,200, and the contractor planned on keying the new floor into the old floor. His price is based on 3 full days labor, which doesn't sound right to me. In any case, this is much more than I'm willing to spend.
The second estimate was $1,200, and the contractor plans on pouring a completely new floor, 4" thick with wire mesh. He thinks it will turn out best if the old concrete is removed first. Removal of the old floor is not included in the estimate, because I would do the work myself. I can afford this, but it's still a bit more than I expected.
What do you guys think of this second estimate? Is it reasonable?
Thanks for your help!
/ Concrete Floor #2
My calc's come to about 7.5 cubic yards - @ $100 per and the mesh, your around $800 + in material alone. I'd think it would be worth $400 in labor at least.
Sounds like a deal to me.
/ Concrete Floor #3
Are you looking for a nice finished floor? If so, rip out the old and pour a single slab. If headroom isn't an issue, don't rip out the old, just pour over the top.
If looks don't matter, leave the old alone. You will have a joint/crack between the old and the new floors.
/ Concrete Floor #4
For labor and materials, I think $1,200 is very reasonable.
I don't know what the existing slab looks like, but since it is your home, I'd think you'd want it to look as nice as possible. Take out what's already there and have one nice slab that you can be proud of.
If you have never busted out slabs before, it really helps to pry it up a little, then break off the pieces with it in the air. When it's flat on the ground, it takes allot of beating. In the air, it breaks off real easy with a sledge hammer.
Have fun,
Eddie
/ Concrete Floor
Thanks very much for the advice, guys!
The floor down there doesn't have to be perfect, but if I'm going to spend the money, I guess it's worth some extra work to make it as nice as possible. I've already removed between 7 and 7.5 yards of dirt down there to level the floor out (two 5-gallon pails at a time), so removing this concrete shouldn't be too bad in comparison.
I was thinking of renting an electric jackhammer, but I'll try lifting the slabs first, like you suggested Eddie. Thanks for the tip!
/ Concrete Floor #6
I was thinking of renting an electric jackhammer.....
Electric jack hammers are useless. If you can't break it out with a sledge as Eddie suggested and absoultely need a jack hammer, then rent a compressor and air hammer.
Trouble is though this will produce vibration that may be a problem if the foundation walls are stacked stones. How old is this place anyways??
If the concrete is really old it can sometimes become extremely hard. You may be lucky though if the original mix was weak, and its a pretty good chance from what you describe that the existing slab was probably home made and hopefully shy on cement.
Good luck!
/ Concrete Floor
The house was built in 1870. The inside of the house was pretty much redone just before I bought it, but the basement didn't get any attention.
With energy costs so high this past winter, I'm working on insulating the floors and plumbing. We decided to upgrade the furnace and ductwork, (the current furnace is an OLD oil furnace converted to natural gas) and I figured this would be the perfect time to get a finished concrete floor down there. Plus, the basement is really dry and dusty, and cutting down on that dust might be better on a new furnace.
Anyway, I tried the sledgehammer in a couple places, and the concrete breaks up easily. The solid concrete is only 2-3 inches thick, with a layer of crumbled concrete/stone underneath.
/ Concrete Floor #8
$1,200.00 reasonable? If you've checked their work history and are comfortable, sign them up before they wake up and realize they quoted you $300.00 for two guys labor for the better part of two days. Wire and poly aren't cheap anymore. Make sure you put down 6mil poly as a vapor barrier. Sand or no, still need it.
Incredible price assuming materials are included. Here, they'd get that much for labor only.
/ Concrete Floor #9
DaveRR,
It is always so nice when people fill in a little bit of their profile, at least minimully where they are from.
/ Concrete Floor #10
Most areas of the USA now pay $4-$5 per SF for a slab with no problems or special work. You will be getting about a $2200 job for most areas of the country. $1200 sounds like you are dealing with a small contractor skirting various issues such as building permits, workmans comp, etc. Don't get me wrong. I have used these guys in the past and all went well. You just need to make sure whether you are dealing with someone like this or someone dumb who will will figure out out about half way through the job he is not making anything and walk off the job unfinished. Several yards of unfinished concrete in your basement would not be a pretty sight. I highly recommend pulling up the old floor and having one new continous floor with wire mesh and expansion joints next to the walls. It will cost you at least 10-15 hours of your own labor to tear up the old floor. It will be worth it in the long run.
Basic 4000 PSI concrete in Florida is now running $125 yd and is about $100 in western NC. These two areas probably represent the extremes of pricing. Your quote of $1200 is very cheap.
/ Concrete Floor #11
My neighbor & I took out a concrete floor in an entire house this way.
We dug a small trench so we could get a hydraulic floor jack under the concrete as a lifting means.
We found that an electric jackhammer worked pretty well when the slab was in the air.
/ Concrete Floor #12
Not sure where you are at but you stated a new furnace was in order and this was part prior to the furnace or in conjunction with.
anyhow I second the poly & also add some foam insulation boards under there too. it will add some height to the pour but will also Help those high heating bills.
just my 2 cents worth
\mark M
/ Concrete Floor
Thanks again for the advice, everyone. I've been side tracked on some other things around the house, and I'm finally getting back to the basement floor.
I just finished breaking up and removing the old floor (what fun!), and the new floor is scheduled to be poured at the end of the month. I have one more question, though.
I have four boulders that I need to deal with. The tops of each boulder are 3-4" above the dirt floor, which would put them at or just below the level of the new floor. I was hoping to remove them from the basement completely, but I've dug around them and they're pretty big. I can probably carry two of them out with some help, but I'd have to come up with another method to remove the other two.
What do you think about burying the boulders right in the basement? The soil is sand, and it would be pretty easy to dig a hole next to each boulder and roll the boulder into the hole. Would this cause cracking or other problems with the new floor? How far below the ground surface would I need to bury them?
I appreciate the advice!
/ Concrete Floor #16
I agree the ele jack hammer is not as effective as the Air hammer BUT, they are far better than swinging a sledge all day. They are cheep to rent and easy to throw in a trunk of a car if need be. This job can't need to full blown air hammer
/ Concrete Floor #17
I haven't used it but this sounds like a perfect opportunity to use CRACKAMITE. At their site, crackamite.com , they say:
CRACKAMITE®, a Non-Explosive Expansive Silent Cracking Agent, is a highly expansive powder composition for stone breaking, granite and marble quarrying, concrete cutting and demolition. CRACKAMITE® is safe, environment friendly and a good and viable alternative to explosives and other traditional methods of quarrying and demolition. CRACKAMITE® is mixed with clean water and poured into pre-drilled holes on rock and concrete. The diluted CRACKAMITE® swells and exerts significant expansive thrust on the hole-wall, fracturing the wall and splitting the rock across the line of the drill holes.
Granite Cutting
Marble Quarrying
Limestone Mining
Concrete Demolition
Rock Breaking
Might give it a try... they say that there is a way to get a free sample... might be just enough to do the few rocks you have... an idea anyway!
/ Concrete Floor #18
Some years back the home that I owned had a large set of steps that was poured with concrete and it was thick in construction. I needed to eliminate the steps so we rented an electric jack hammer for a day. It made short work of the project and I'm confident that it will make your job easier too.
/ Concrete Floor
I'll have to look into that product some more, texasjohn. I'm not sure how I'd split these boulders without using something like that.
These rocks are very hard and very smooth; there are no obvious cracks or seams where I could try to split them. I did rent an electric jackhammer to break up the floor, btw (it worked great!), but it barely scratched these boulders.
/ Concrete Floor #20
Make sure that material is included in both estimates because if the one for 1200 didn't include material then in the end both estimates would be about the same. Also how deep a pour is it going to be according to each estimate. In the area where we live the last concrete I had poured there was three grade levels of cement a 5 bag mix a 5 1/2 bag mix and a 6 bag mix. I paid about $80 a cubic yard for the 5 1/2 mix but you had to order 7 yards or more or there would have been an additional charge I paid $35 a yard to have it poured and dressed down with a machine. It is slick as glass practically[ if it is wet it is dangerous] that price didn't include having releif cuts in it and I never got releif cuts but it hasn't cracked anywhere yet and that has been about 3 years ago. The man that poured mine gave me a price per yard for labor only and I ordered the concret from the plant myself. I hope this gives you some kind of idea good luck with your project.
Landhonor 10" Utility Blower Fan (A66408)
Landhonor 10"...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A65643)
2008 STOUGHTON...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
