Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,980
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Added a mudroom onto house. Has concrete floor. When the wife told the construction people what she wanted, she said she wanted a floor drain. My wife fails to understand that words have meanings.
What she WANTED was a drain to use for the sink. The drain would attach to the downspout drains and go to the woods, verses into septic system (no way to reach it NOR any way to reach household plumbing)
What she WANTED was a wall mounted connector to attach the sink to.....what she told them was a floor drain. Therefore, what she GOT was a drain in the corner of the room, on the floor. To add insult to the injury, the floor has a slope to the drain (duh!)
Well, that's NOT what she wanted.... and now, when we put the vanity cabinet where it will be (room is 90% in drywall, floor is still raw concrete) anyway, because of the spacing and the slope to the drain, the vanity cabinet has a BAD rock/roll problem. Probably 3/4" out of level from one edge to the other (one edge is pretty close to slope of drain, other is on flat ground)
I know we also have a high spot on the floor. No idea how high, let's call it 3/8" (again, no clue) She wants to put tile down on this floor so now the high spot and the slope are going to be an issue. She likes the idea of 2x2 tiles which will only make these issues worse.
*IDEA* What if we level the floor!
So now I'm looking around for how to level the floor and, what to use for it. I've not taken a (straight level) to the BUMP in the floor to gauge it but when we were setting the drywall down on edge to adjust things, that was the only high spot that was obvious. I might be able to grind that down if it's just in that spot and then only focus on the slope for the floor drain.
So that's the gist of the back story.
I've never done something like this. What might I use? Did a cursory search and found something like this: https://www.bobvila.com/articles/leveling-a-concrete-floor/
I've told the wife she should use 12x12 tiles instead of 24x24 as it will follow the contour a bit easier (but she LOVES big tile)...
Side question....on the floor drain, it APPEARS that the drain assembly itself (which is embedded into the concrete) is a 6x6 square assembly. Has a 'bowl' in it to collect water, BUT, the actual drain comes up THROUGH the bowl so the bowl is actually more to seperate things like a sediment filter. The drain part itself I'm guessing is 1 1/4 to maybe 1 1/2". This is a mud room sink. I don't have anything to connect to so I'm thinking take the tailpiece and P-trap from the sink and simply "stuff" the output tube into this drain hole (I'm hoping the ID and OD sizes mate verses being the same)
Her lack of attention to verbal details is what got us into this. After all, they should KNOW what she meant..... (sigh).
Thoughts?
Thoughts?
