Computer Woes
/ Computer Woes
</font><font color="blue" class="small">( Very few even have jumper settings any more )</font>
Unfortunately, the manual for this hard drive talks extensively about those jumper settings /forums/images/graemlins/frown.gif, although it does also mention that XP might recognize it. Oh well, when I get time, I'll get back to the manual.
/ Computer Woes #52
Thats usually my luck as well though the last HD I installed. Maxtor I believe came set as a Master and I a Setup disk with it as well. Enjoy...It's almost Friday and Sat. I get to STAY HOME and work......hmmmmm something sound wrong with that last part... /forums/images/graemlins/wink.gif
/ Computer Woes
</font><font color="blue" class="small">( Maxtor I believe came set as a Master and I a Setup disk with it as well. )</font>
Yep, so did this one, and the 20 GB that's in the computer is a Maxtor Ultra also.
/ Computer Woes
</font><font color="blue" class="small">( So how's the project coming, Bird? )</font>
Probably about like you'd expect from a computer illiterate. /forums/images/graemlins/frown.gif /forums/images/graemlins/laugh.gif I installed the new hard drive, disconnected the cables from the original hard drive and connected them to the new one. As for the jumpers, I didn't mess with them at all; just left them as they were, which appears to me to be "cable select" on both drives. I disconnected the ribbon and power cables from the old drive and connnected the same to the new drive. Now the instructions that came with the new drive talk about modifying either the BIOS or CMOS, and tell what you'll see in the box on the screen ('cept you don't see anything like that on my screen), so I skipped that step and formatted the new drive. The instructions also mention formatting and "partitioning" the new drive, but I never saw any option or opportunity to do any "partitioning". So . . ., it was formatted with the single partition. Then I tried to install Windows XP from the CD I got a couple of years ago from Dell. As far as I could get was for it to boot to a message "NTLDR is missing""Press Ctrl+Atl+Del to restart". The instructions say when you get that to insert the CD and restart. Easy enough, right? But you just get that same message again. Now from there, the instructions shoot plumb over my head, talking about things like a "cylinder limitation jumper", buying additional jumpers, unplugging and plugging cable to or from ATAPI devices or drives, etc. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
For one thing, the XP CD I have is labelled "For distribution with a new PC only. For product support, contact the manufacturer of your PC" and I don't know for sure that it's even any good. I think I mentioned before that when I got it from Dell and "upgraded" from ME to XP, we had all kinds of weird problems, and when we finally got it working, the hard drive was drive E instead of C, the floppy stayed as A, the Zip drive is C, and the CD-ROM is D.
So for now, I have both hard drives hooked up, the new drive is F, and there's no problem using it for storage. I can copy files to and from it just fine, but since I'm only using about half the original 20GB drive, I really don't need another 80GB for backups. /forums/images/graemlins/grin.gif
As much as I hate to turn loose of any money right now, I'd be willing to spend the couple of hundred a genuine, in the box, from Microsoft, version of Windows XP costs if I knew I could solve the problem with it. Since most things are working OK on this contraption, I'm not in any big hurry, but I'll probably go back to Fry's service department this week and see if they're confident they could do whatever it takes to make the new drive the boot drive, call it drive C, preferably (but not absolutely required) partition it, and install a new version of XP on it. If so, I'll probably let them do it.
I seem to recall something else about some different file systems; FAT 32 and sumpin' else and think the old drive is FAT 32 and the new one may be the "sumpin' else". /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
Who said ignorance has no limits? /forums/images/graemlins/crazy.gif
/ Computer Woes #56
Somethin' else = NTFS. It is a much better filesystem than FAT (which is essentially '70s technology /forums/images/graemlins/smile.gif) and I don't think that having them co-exist this way is any problem...
/ Computer Woes #57
Hey Bird-
If you go to the Microsoft website you can download the XP startup disks (and put them on 5- 3 1/2" floppy's then boot from them), your OEM CD should work. Since you're back to the old drive, just download the files and copy to 3 1/2's. I'm guessing you didn't get to the BIOS to tell the PC to boot from CD. Even if you did sometimes the OEM CD's don't boot on some machines (especially Dells). If you did change to boot from CD, just change it back to boot from "A" and go through the routine using the floppys.
You'll probably have to call Microsoft after you reload, to get the copy of XP re-registered, but that won't be a problem, just tell them the details and they'll give you an unlock code about a mile long.
Good luck!
/ Computer Woes #58
/ Computer Woes #59
Bird,
This problem is documented in the Microsoft Knowledge base.
Microsoft Link
Hope this helps
/ Computer Woes
I'd like to thank all of you for the information and assistance. I learned a little bit, but in the end decided that some things are best left to those who know best. /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif So I put my computer in the computer hospital yesterday afternoon and got it back this afternoon. I had installed the new hard drive, but had the computer store add 256 MB of memory, format both hard drives for the NTFS file system, wipe everything out, make the new 80 GB hard drive the boot drive (even call it drive C: instead of E or F) and re-install Windows XP. So, for the last 5 hours I've been re-installing my other software (and no way I can read all the posts that have been made on the forum the 36 hours or so). In fact, I probably won't finish loading everything tonight, and the weather's so pretty just got to go play golf tomorrow. /forums/images/graemlins/wink.gif
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2012 BMW 328i Coupe (A59231)
2012 BMW 328i...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
KUBOTA U55-5 EXCAVATOR (A59823)
KUBOTA U55-5...
