Computer Trouble
/ Computer Trouble #21
Ok, First off how much ram do you have, You said 256k. If that is true then for GET MORE RAM. you need at least 64mb to run win95. If thats really 256mb then you have enough ram. Your machine is a bit slow by todays standard, but is fine. Your 3/4 full disk is an issue. defragmenting a full disk becomes harder and harder. You can get a USB card for under $39 at most stores. You might look into a Motherboard swap, many computer stores have ~$100-$200 motherboard memory swaps. The rest of what you have is still usable. with the swap you get the USB included .
The big kiicker is for $300, at least around here I can get a 900mhz machine, 128mb ram, 30gb disk, video,speakers,keyboard, cdrom, mouse for $295. Check around. Find the little mom and pop shops for the best deals.
/ Computer Trouble
Many thanks for all the information from everyone. I think I'm going to go with windows 98se as scruffy mentioned. I do like mike's idea about windows2000 because I don't run any games. It's all going to get driven by price. I found a new (not upgrade) w98se for $99. The only problem is I don't remember where, I swore I bookmarked/w3tcompact/icons/crazy.gif. I looked a little and found w2000 new for around $200. So well see. I hope to do the switch over next week if work isn't to busy.
Thanks for the memory explanation wingnut.
Anything important I need to save or do other than saving important files before formatting the hard drive?
/ Computer Trouble #23
Save any pictures, your bookmarks (from IE or Netscape Navigator, old e-mail if you think you need them. All files you've created (such as Excel, Word, Access). Not the applications...you should have a CD-ROM to reload them. Just keep the data files you have made.
Really think about what you want or need to keep.
If there are any applications (utilities, for example) you downoaded from the Internet, save them or know where you can download them again.
Once you format, they're gone for good.
BTW, I think you can beat the Win 98SE price on eBay. Just make sure it's the full install and not the upgrade disk.
/ Computer Trouble #24
First of all, forget about XP. It needs a newer, faster machine, plus most of your old stuff won't have XP drivers anyway.
If you did nothing but a wipe and clean install of your OS you would get some improvement - at least back to original speed.
256M RAM should be fine for most uses.
To use USB you will need to go to Windows 98. I had much better luck with the Second Edition in terms of stability.
You will have to download Windows 98 drivers for the various components, but they will probably be available.
Bottom line, I'd wipe the hard drive (or better still, get a newer, bigger one) and install Windows 98SE on it, add the USB board, and your good to go.
/ Computer Trouble #25
<font color=blue>I've found the only sure way to avoid bad things is to close all the apps, and shut down completely - a cold boot. (leave the swicth off for 10 seconds or so).</font color=blue>
If you're just trying to clean up software issues (memory leaks, etc.), I can't see what leaving the system off for 10 seconds will do... When I do a cold reboot (very rarely with Windows 2000 /w3tcompact/icons/smile.gif), I'll keep it off for a couple seconds but that is just to let the power supply "settle"... Not sure if this is necessary, but, hey, I'm a software guy! /w3tcompact/icons/eyes.gif
/ Computer Trouble #26
<font color=blue>I looked a little and found w2000 new for around $200.</font color=blue>
I'm sure you can beat this... pricewatch or <A target="_blank" HREF=http://www.pricegrabber.com/search_getprod.php/masterid=217635/ut=9c99fff3262dc0ed/>pricegrabber</A>. They had new versions from vendors for about $118 and $137 respectively.
/ Computer Trouble #27
cold boot is a cold boot is a cold boot ... turning off the power for long enough to make sure everything actally powered down. 2 seconds is usually "considered" to be too short and my experience with turning off and on sh0ows that to be true. Most folks say 5 seconds ... but since I'm concervative I make it 10. Why? Well ... I don't time it by a stop watch so at least I'm pretty sure it was long enough.
You don't know how it would solve a software problem like a memory leak? ... ok, ok I'll not make any snide comments but I think that in a cold boot, the software problem (since software only runs when the machine is on) goes away ... and memory will definietly be starting from scratch.
I'm happy for you that your WinNT (2k) system never needs to be rebooted. I wish I could say the same for all the NT servers we run ... Cycling them is the only way of ensuring that they perform their one and only task (file servers) all week long.
On the other hand, my 98SE machine runs 20-30 differnt programs every day and, since I only have 128mb of RAM (twice what the company bought - but I'm a "rebel"), and have to open and close programs constantly ... I get to reboot a lot.
The day they retire this eCommerce program that is java-based and runs on MS's browsers on an NT servers ... will be the day you'll hear me cheering whereever you happen to be!!!
/ Computer Trouble #28
<font color=blue>You don't know how it would solve a software problem like a memory leak? ... ok, ok I'll not make any snide comments but I think that in a cold boot, the software problem (since software only runs when the machine is on) goes away ... and memory will definietly be starting from scratch.</font color=blue>
I didn't say that a cold boot wouldn't solve memory problems, I said a cold boot with a 10 second delay wouldn't help solve memory problems any more than a cold boot with a few second delay...
<font color=blue>I'm concervative</font color=blue>
Ya think? /w3tcompact/icons/smile.gif
/ Computer Trouble #29
Personally, I would throw my hat in the 5-10 no power ring. Longer, if I have the patience. I have found (on a consistant basis) that the longer time with the power off, the better the results on bootup. Many times, I will power it down, walk off and get a cup of coffee, etc, come back and it will work as it should on bootup, but the short powerdown, and back up, just does not give time for things to clear.
Remember, in just powering down, you should wait a minimum of 5 seconds after the shutdown before turning the power off....another 10 seconds after power off, is definately beneficial. IMHO
/ Computer Trouble #30
I was told by several technicians over the years...let the hard drive spin down on a cold boot...this should be ~90 seconds.
/ Computer Trouble #31
I don't want to get into a long discussion about this because I don't have the facts to get deep... But, /w3tcompact/icons/smile.gif in terms of <font color=red>clearing memory leaks</font color=red> (because that is what we were talking about), any cold boot should fix'em. I know that some BIOSes clear every memory location and most if not all do a complete memory test on a cold boot. With a cold boot, everything in RAM is loaded anew and the processor reset.
Now, how much time you should keep the system off with regards to what's good for the hardware; I'll leave that to the hardware geeks... (altho, i don't remember any problems with my "few" second rule in the zillions of cold reboots i've performed over the past ^$$@*#@&* years... /w3tcompact/icons/eyes.gif just had a thought... how much older i would be now if i waited 10+ seconds on all those boots!?!? /w3tcompact/icons/laugh.gif)
ok... i'm done...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
Location (A63116)
Location (A63116)
UNUSED RAYTREE RTSG30 - 30" STUMP GRINDER (A62131)
UNUSED RAYTREE...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
