Computer memory question
/ Computer memory question #21
Sounds like alot of buffering ( for speed) is going to happen..
soundguy
/ Computer memory question #22
soundguy
Yep that's what MS said. If you can cache the whole Exchange store...it should run faster. It's still weird to look at...this is a 10gig ram server that's using almost 11 gig. :D
/ Computer memory question #23
Just a thought here but have you tried to use some flash memory and Vista's ReadyBoost. With your 1g you could go up to 2.5g with USB flash drive and get a very inexpensive boost in performance. I currently run Vista with 2g memory and another 2g flash drive.
If you have questions just go to the "Help and Support" and type in Readyboost.
/ Computer memory question #24
Speak more on this subject.
I had a friend with a sony that could use memory sticks.. but will vista let you use flash drives as ram?
soundguy
/ Computer memory question #25
/ Computer memory question #26
Interesting read. Anyone know if the SD is better than a USB flash drive?
anyone here using either?
soundguy
That is a slick setup and since my main use on this computer is the internet and photo editing it would help out (not so much the internet but with photos).
What do these USB flash drives that can use this feature usually cost?
/ Computer memory question #28
I just bought bulk packaged 4gb usb drives for 19.99 and 2 gb SD cards for 13.99. They also had 8gb usb drives for 29.99 under the checkout counter. Happened to be in the big city last week & stopped in for some additional wi-fi hardware.
Unlike Best Buy these guys stock what they advertise!!
Micro Center Online | the center of .computer shopping
/ Computer memory question #29
I have an Ativa (Office Depot) 2Gb USB drive. Had to try this. Allocated 1.5Gb and it sure seemed to speed up browsing and reading TBN.
Vernon
/ Computer memory question #30
When shopping for these drives make sure that the packaging lists that it supports Windows ReadyBoost. I have not seen any of the cheaper ones that do. I stopped at Sam's today and saw a package of 3-2G units for about $70. The packaging BOLDLY stated that it supports Windows ReadbyBoost. Saw the same one on line...here is the link
Sam's Club - Verbatim Store 'n' Go USB Drive - 2GB - 3 pk.
Would these flash drives work independent of my computer? What I mean is my computer can only accept up to two gig of ram and I can buy two 1 gig modules for around $50 and sell off my two 512's on ebay or some site like that. But if I found a good deal on a flash drive would it still work if my system is maxed out already?:confused:
/ Computer memory question #32
Short Answer: Yes
Longer Answer: Absolutely Yes
From Vista Help:
"The recommended amount of memory to use for Windows ReadyBoost acceleration is one to three times the amount of random access memory (RAM) installed in your computer. For instance, if your computer has 512 megabytes (MB) of RAM and you plug in a 4 gigabyte (GB) USB flash drive, setting aside from 512 MB to 1.5 GB of that drive will offer the best performance boost. The minimum size for any USB flash drive to work with Windows ReadyBoost is 256 MB."
If you buy the new RAM to max your system out at 2g (same as mine) you can then use a USB storage device from 2g to 6g for optimum performance. This is in additional to your 2g of RAM.
For example, iif you upgrade your RAM to 2G and you purchase an 8G USB storage device that supports Readyboost you can allocate from 2G to 6G of that space for Vista to use as additional memory. This allocation is determined when you plug the device into your USB port. A window pops up asking if you want to use the device for Readyboost. If you say Yes, then gives you an option of how much of the device's storage you want to make available. You can pick anywhere from 2G to 6G for optimum performance. The remainder of the storage is available for other uses.
Hope this helps clarify it for you.
Licklog
Thanks Licklog, that answered my question perfectly.
/ Computer memory question #34
Yes.
2G of memory made a world of difference for me, with Vista. I tend to open two or three applications at the same time and a number of tabs in explorer. After awhile the system would slow to a crawl with one 512M module.
First I had one 512, then I added a second 512. That did not work well. A bit faster but it had a bug from time to time at shut down. Never did get rid of the bug with the two different memory cards even if it did pass every memory test.
Then I replaced the two 512's with two new 1Gs. The system is stable and much faster now. I will have at least 2G or more in all new computer in the future.
I found a memory store that ships from the south San Francisco bay area with good prices that will also take back your old memory, sell it on a used memory market and then send you back some money. I never did send back the two used 512's.
/ Computer memory question #35
Also remember the SD HC(high capacity) card come in higher speeds for the 400 MP :D digital cameras. There is class 2, 4, 6. The 6 is 6 MB/s transfer rate. My boss has a big digital SLR with a 32gig SDHC, takes pics as fast as you want.
Rob
/ Computer memory question #37
Robert_in_NY said:
It will cost me around $53 for 2 - 1 gig modules.
What would be a good way to sell my 512 modules? Ebay?
Most people don't want to buy unless they can see them work in a system, or on a memory checker. If you have a computer show in town near you, take them and have them check them and offer to sell them to the memory vendor. They swap and sell all the time.
429835 (A61166)
429835 (A61166)
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
Gravely Field Cultivator Attachment (A65640)
Gravely Field...
2016 GMC Sierra 1500 Crew Cab Pickup Truck (A64556)
2016 GMC Sierra...
Gravity Box (A65640)
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
