compression testing
/ compression testing #1
steviep
Milton NH
2001 JD 4300
Does anyone know how to test the compression on a 2001 JD 4300 with a yanmah 3 cylinder diesel engine.
/ compression testing #2
I never did on a diesel to answer your question. However, if mine start right up, especially on a 40 degree day, I don't worry about compression.
I'd guess you'd get a tester capable of 300 give or take pounds of pressure and use an injector hole with the other injectors removed and a good, fresh battery. I think compression numbers will be around 2-300 on a diesel......all an uneducated guess. Surely a google search for compression numbers on your engine or one similar would be available.
My problem is I seem to be getting a lot of air blowing out the valve cover air tube, trying to check if I have a bad head gasket or maybe a bad ring.
/ compression testing #4
You can purchase a DIESEL compression tester on ebay or harbor freight.. guage must go over 300psi,,
A master compr. tester is around 100.00 has adaptors for most injectors and glow plug holes.. a compression tester w/ adaptors to go specifically into glow plugs costs around 50.00..
/ compression testing #5
If excessive compression leaks by the piston rings on the power half of the 4 cycles, it will pressurize the crankcase and all things attached to it...aka valve train and force gasses out the crankcase breather.
I have done 3 things with diesels over the years on separate tractors:
Overhauled the engine because of hard starting as I mentioned when it wasn't bad enough weather for hard starting without assistance. Top end was shot. Ford 3000
Drilled and tapped a hole in the intake manifold and with a piece of garden hose, routed the pipe outlet to that manifold because the tractor was easy to start and pulled hard. Did not seem to need overhauling (JD 4010 6 cyl)
Used Power Services and Sea Foam chemical treatments to clean up the injectors and decarbonize the pistons and ring-ring grove interfaces which about solved the problem, including blue and black smoke out the tail pipe. Ford 2000
Properly call the dealer Tuesday, I have been trying to find someone local but not having good luck.
/ compression testing #7
You'll need a guage with more like 500 psi capability for most diesels. 400-500 psi is generally good compression on a diesel.
/ compression testing #8
Would certainly be better. I hadn't read the numbers in awhile. I remembered it was at least 2x what gas engines are so I just added the rubber words, "I think". Grin
I have owned and overhauled tractor diesels over the last 37 years and still don't have a meter for it, nor have ever directly measured compression. Reason was other means found the smoking gun and I didn't want to fool with finding a meter and pulling the injectors and getting them purged when finished and all that. I did get a 0-5k oil filled gauge for measuring hydraulic pump pressure on my Fords however.
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
