compression relief
/ compression relief #1
takins
Does anybody know where the compression release is on my 2210d?
/ compression relief #2
Starting at the top of the engine--there should be a short lever attached to a rod that goes inside the valve cover. There should be a lever for each cylinder--in you case 2. These should be attached to a rod that extends back through the dash and that is your compression relief. Pull it to release the compression. It will return to normal position when you release it.
Mike
/ compression relief #3
On my 2210D, the rod for the compression release that comes thru the dash needs to be rotated not pulled. Rotate it about 90ー anti-clockwise. If you can not rotate it, you may have to "exercise" the connection atop the engine.
Keith
1995 T800 TRI/A DUMP TRUCK TRACTOR (A67148)
1995 T800 TRI/A...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
UNUSED PARBREAK SST23 DEER SHAPED TARGET (A65055)
UNUSED PARBREAK...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2017 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2017 INTERNATIONAL...
