compression relief
   / compression relief #1
takins
Does anybody know where the compression release is on my 2210d?
   / compression relief #2
Starting at the top of the engine--there should be a short lever attached to a rod that goes inside the valve cover. There should be a lever for each cylinder--in you case 2. These should be attached to a rod that extends back through the dash and that is your compression relief. Pull it to release the compression. It will return to normal position when you release it.
Mike
   / compression relief #3
On my 2210D, the rod for the compression release that comes thru the dash needs to be rotated not pulled. Rotate it about 90ー anti-clockwise. If you can not rotate it, you may have to "exercise" the connection atop the engine.
Keith
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
CONTAINMENT SKID MOUNTED (A53843)
CONTAINMENT SKID...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
KUBOTA M7-132 (A53084)
