Compressed Air Line Question
   / Compressed Air Line Question #61
Good, then I will just deal with statements you make that could lead others into a misunderstanding of pertinent physical issues and how they relate.
Enjoy.
   / Compressed Air Line Question #64
The Plastics Pipe Institute recommends against the use of thermoplastic pipe to transport compressed air or other compressed gases or the testing of such piping with compressed air or other compressed gases in exposed above ground locations, e.g. in exposed plant piping. It is recommended that all thermoplastic piping used to transport compressed air or other compressed gases be buried underground or encased in shatter-resistant materials. In designing thermoplastic piping to transport compressed air or other compressed gases, the strength at the operating temperature, the pressure, the energetics, and specific failure mechanism need to be evaluated.
And here is the Government Link
Safety and Health Information Bulletins | The Use of Polyvinyl Chloride (PVC) Pipe in Above ground Installations
There ya go.
   / Compressed Air Line Question #65
Re diesel and PVC,
I used some re-enforced clear PVC as a fuel line to fuel my tractor as I liked the flexibility.
Within a month I could have used the PVC as a fishing pole it got so hard and stiff.
Looks like there is a reaction between PVC and fuel.
   / Compressed Air Line Question #66
It isn't difficult to turn a pipe threader, but I cant count the number of leaks I have encountered when testing threaded pipe installed by professional pipe fitters. You need high quality dies and good cutting oil to make good threads and then properly tightened, not too tight as to damage the threads but tight enough to not leak which takes a bit of experience to get it right.
You also need to use schedule 80 pipe because if using schedule 40, the threading cuts away over half the wall thickness which leaves a very weak joint.
They might be professional, but they must really suck at it.
If the threads are fair to midland a good Teflon paste will seal it up as will LocTite 242. Tape is iffy.
Sch. 80 pipe should never have to be use for light air. Sch. 40 is much cheaper and works fine. The only sch. 40 that failed on us is when an air drop is hit with a fork lift or a scissors lift or some other man caused problem. that shears them off, but the same would happen with sch 80.
   / Compressed Air Line Question #67
Here is a quote for what I posted about being underground and/or encased.
I use black poly which does not present the shattering problem. --The thicker wall, rated ~ 200psi.-- But still only for feeds to the work area - not in the work area. I do have a 4' section above ground in a corner in the heat in the barn. Its only 160psi rated at 70F. Its been fine running at 150 PSI for 17 yrs.
   / Compressed Air Line Question #68
   / Compressed Air Line Question #70
Here is an option, DOT Air Brake Tubing- Velvac 1 2 Blue Nylon Air Hose Tubing Dot Approved 1 Foot Roll 4deg to 2degF | eBay
It's easy to attach standard fittings you just have to use brass inserts. When you compress the ferrel it clamps the hose to the insert.
There is over a million feet of it in use, just look when a semi goes past! this is what is used for tractor and trailer air lines. Hoses are used from frame to axles.
UNUSED SWICT 72" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 72"...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2015 FORD F550 XLT SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XLT...
49" X 74" EXPANDED METAL RAMP GATE (A54756)
49" X 74" EXPANDED...
2014 Chevrolet Equinox SUV (A53424)
2014 Chevrolet...
2014 Toro Workman HD 07369 Utility Cart (A55851)
2014 Toro Workman...
