Compressed Air Leaks
/ Compressed Air Leaks #1
jedens
La Veta, CO
Kubota 4610
I bought one of the pressurized sand blasters for connection to my compressor. Bought it from Harbor Freight and it came in many pieces. I can't seem to get the connections tight no matter how much teflon tape I put on them. Its not just one connection that leaks but about 5 or 6 of them. Is there something better than teflon tape? I've taken it apart several times to try to fix them but it is a real pain to disconnect and as I think I've got one connection fixed I've accidentally loosed another and it leaks. Would it work if I put silicon calking around the outside of each of the connection joints completely sealing them while leaving the teflon tape on the threads? Any suggestions appreciated.
/ Compressed Air Leaks #2
When I installed a bunch of steel pipe for my compressor I had the same problem. Teflon tape just wouldn't do the job. Then while building our house I watched the gas guys put in some pipe. They not only use teflon tape but also add some of the white pipe muck on top of the tape. When I did it this way I had no problem whatsoever. Of course, that would require you taking them apart again.
Jeff
/ Compressed Air Leaks #3
There's some stuff called "goop" as well as other products that come in tubes that are specifically designed as sealers without setting up. Silicone might work but getting them apart afterward may be hard.
/ Compressed Air Leaks #5
Around here, commonly called "pipe dope". spread it on the threads, thread everything together..........works great. It can be bought at any hardware or big box store in the plumbing section.
Jerry
/ Compressed Air Leaks #6
I've had problems with some cheap brass fittings in the past. I gave them my usual "down tight" and they leaked. The more I tried to crank them down, the more they leaked, probably since I had deformed them. It was so bad I had to buy a replacement hose and fittings. I've learned to have a "lighter hand" with plumbing and I've had more success. I hope the pipe dope works for you.
/ Compressed Air Leaks #7
The teflon pipe dope is supposed to be God's gift to high pressure lines. I used it on some hydraulic lines and they leaked as though I used nothing. I previously tried the yellow teflon tape that's for oils and such. I went back over all the joints with the regular water-pipe-joint compound and (finally)that seemed to work. This is on a system with around 2,000 psi. THe only down side I can see with using any kind of dope on the fittings is if it get's blown through to the air driven item. Maybe using the air gun for a bit would eject any thing that would come loose.
/ Compressed Air Leaks #8
Try to get your hands on some Gasoila Softset or Laco Teflon Paste. They stay pliable almost forever. Stuff like the red Gasoila hardens like laquer, and is a bit more fussy.
Just be glad you're not doing stainless. That's a tape 'n paste job and still is hard to get sealed...............chim
/ Compressed Air Leaks #9
I had the same problem with a sprinkler system I installed. It had about 150 PSI at the inlet. Those valves I sealed with tape leaked. I changed them and used Rector Seal T that is a pipe dope approved for everything (including ABS). No more leaks.
With teflon tape I've been told you use three wraps around the pipe. The down side is that you are adding dimension to the pipe. With pipe dope you are only sealing the voids as you thread it into the fitting. I use a lot of teflon tape on pipe joints and buy it you the case. When I really am worried about a joint I use the Rector Seal and never have a problem. One tip is to spread it on the pipe and the coupling threads for a secure seal.
/ Compressed Air Leaks #10
At work all we use is Locktite 567 PST
it seals all pipes including SS and works for
all fuels and water.
If the tooling we build has pipe tape it 'VOIDS' the
warranty on valving and controls.
The liquid sealer works great and we hardly ever
have leaks (usually bad fittings).
NAPA seals a liquid pipe sealer w/ teflon that
I used when trucking and it works very well too.
Look at the threads very close and u will see
jagged edges on them,this usually ruins the
tape when assembling.
Thanks to everyone for all the suggestions. I'm going to the hardware store later today and get some pipe dope and Locktite. I'll let you know how it holds.
/ Compressed Air Leaks #12
Stainless is harder to seal than brass/galvanized steel? That's a relief, I thought it was just me. I just put in an auxillary water line for irrigation and ended up using stainless for the above-ground portion (couldn't find brass locally, SS was almost as cheap mail order). I had a bear of a time getting it sealed with tape. I ended up going back with Rectorseal on most of it, and that seemed to do a lot better. I think I may re-do the remaining part, just for grins. I need to take the above-ground part in for the winter anyway.
Is this due to the fractured-looking appearance of the threads? I was surprised to see this on my (high-dollar) fittings, but it sounds like it may be the nature of the material? Anyway, thanks for the good info.
Kevin
/ Compressed Air Leaks #13
Why did you use Stainless Steel or Brass for an irrigation system ... this must be high pressure ...
/ Compressed Air Leaks #14
Threads are more difficult to cut cleanly on stainless, and I think the hardness of the stainless limits just how much it will deform to seal theads. I also galls sometimes if you try to "dry fit" pieces together. On applications where it's acceptable, our guys prefer to weld stainless rather than thread it.............chim
/ Compressed Air Leaks #15
I needed to use an RP backflow device so I could inject fertilizer. The RP has to be installed above ground. Any pipe under continuous pressure that is less than 18" deep needs to be metal. Also, standard PVC is not UV resistant, so having it exposed is not good. I thought about using galvanized steel, but I've seen places where it's rotted through (well, oxidized I suppose) in a remarkably short time. We have extremely acidic soil, so I figured it would probably go even faster. Thus, I wanted to use brass. It turned out getting stainless was a lot easier and just as cheap. So, after the long way around the barn, that's why the stainless. It only goes from the tee in my main water line to where the downstream side of the RP goes back to 18", then it's PVC from there.
I wish it was due to high pressure. My well only recovers at 12GPM, and the dynamic pressure I'm left to work with is only 31PSI, so I'm marginal at the sprinkler heads, and I have to use a lot more zones than I would like. Oh well, my neighbor only makes 1GPM on her well, so I guess it could be worse (the neighbor on the other side makes 30+).
Kevin
/ Compressed Air Leaks #16
Thanks .. I’m on a well also and for the system that I have here in Florida I have the antisphon valves above ground and used schedule 40 PVC through out … I have a back flow preventer valve underground before all of this and after the house water so that nothing gets in the house water … maybe a little much but I feel better … I did cover the valves and the exposed PVC with a small structure made of PT plywood that looks some thing like a box and I think it will be fine … I didn’t realize PVC had that big of a problem with UV … I covered it up to hide the pipes and valves ….
/ Compressed Air Leaks #17
I should have added that you need to check your local code requirements. My parents' system in Florida is very similar to yours, but it wouldn't do as well here with ground freeze. The RP device has unions on each side so that it can be brought in for the winter.
I've been told that the grey sched 80 PVC has been treated for UV, but I would be leery of that. That was at Lowe's/Home Depot, and I think half the people that work there will answer any question, whether they have a clue or not. If you have PVC exposed, you should at least paint it, preferably something reflective. If you leave it exposed to UV, it will eventually fail. Your PT covers are probably as good/better than painting.
Kevin
/ Compressed Air Leaks #18
jedens
I realize this thread has gone various directions since you first posted but thought I might respond to your initial problem. First of all, I have one fo the harbor freight 40 pound sand blasters my self. It leaks like a sieve. I don't mind cause I go through air at an alarming rate. I get a 20% duty cycle with a sears "5 hp" compressor. I might get 25% if I fixed all the leaks.
Pipe dope, sold at home depot and all hardware stores, is INFINATELY better than teflon tape. Cheaper, easier to use and works much better, or so I have been told. I used the tape that came with mine and mine leaks like a sieve.
Basic pipe dope is good for way more than the 100 PSI you are gonna put into our sand blaster. I would go with it if you really want to get rid of your leaks. Otherwise, just realize that as soon as you open your nozel that you are going through tens of cfm of air so leaks are insignificant..
/ Compressed Air Leaks #19
Look at the PVC conduit, it says it is UV resistant.
If not then all the utility poles w/ drops are going to
have to be replaced sometime.
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
Coleman Back Home Screen House (A62613)
Coleman Back Home...
