Compost turner.
/ Compost turner. #1
ferrari99
Australia
Kubota BX2200, Ferrari 340
What do you think about getting a tiller gearbox and turning it into a compost turner like the big ones but on a small scale?
/ Compost turner.
/ Compost turner. #3
Never seen one before - how is it supposed to work?
/ Compost turner. #4
Great idea. If you look on YouTube the videos are impressive for compost turnersI don't think a 2 wheel machine could tow or push one side like a 4 wheel tractor, (see YouTube videos) but maybe ride on top of the compost pile?
Good luck
Sent from my iPad using TractorByNet
/ Compost turner.
The drum has flails mounted to it (not on the model) which are spiraled round the drum, to one side of center they are anti-clockwise to the other clockwise. So the compost on the outside gets 'sucked' to the middle and middle goes to the outside so eventually all the material gets a turn in the middle (the hottest point). Hope that helps.
/ Compost turner. #7
I usta have a book called "The Joy of Gardening" by Dick Raymond. It was really just one big promotional for Troy Bilts. It showed his idea of composting between two sheets of plywood. You'd pound several posts in the ground 6 or so inches wider than the tiller. Then, you rip a sheet of plywood lengthwise and wire them to the inside of the stakes. It's not the ideal size for a compost pile (2X2X8 versus 3X3X3), but it was in a book heavily promoting a troy-bilt, so it must be true....
/ Compost turner. #8
I turned piles yesterday. The fel works fine, "Turning" consists of up ending the pile about it's own base. Lift and dump, lift and dump. So now the pile is ten feet to the right of where it was. Next time, I'll tip it back ;-)
/ Compost turner.
I agree that a FEL works fine but it doesn't help if you don't have one.
/ Compost turner.
Good luck
You could take the wheel off and 'divert' the drive to the wheel on the other side of the turner.
/ Compost turner. #11
Neat -thanks for the info
/ Compost turner. #13
just tossing it out there ... for much smaller piles.
a 2 stage walk behind snow blower , fitted with looser fitting augers and some "tines" to make up the difference ... walk into the pile, and blow to the left ( or right) with the chute aimed low and close... ( move the pile to the left or right in a row )
/ Compost turner.
Good idea but we don't have many snowblowers down under.
/ Compost turner.
I had another idea, that is to have a trailer (see pic 2) that can move bins (see pic 3) and tip them. Then dig into the side of a hill (see pic 1) and so you can put an empty bin in the bottom and tip the full one from the top. The red thing on the trailer in pic 2 is a manual hydraulic and the blue rod on the trailer goes through the yellow hole on the bin. You will notice the rod is not in the center of the bin that is so that it is easy to tip.
/ Compost turner.
How much will a walking tractor (approx. BCS 853) tow with dual wheels and weights?
/ Compost turner. #17
The 107d has a 4wd trailer that can handle 2000 lbs. So maybe an 853 could do something similar.
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2025 Swict 78in Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
John Deere 412R (A63688)
John Deere 412R...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
