Paddy
Veteran Member
Anyone here heard of or are playing with compost heat? There was a French farmer back in the '70's who experimented with collecting the heat from large compost piles. He would lay down 4" perforated pipe first to allow the pile to breath. Then layers of appropriate compost mixed with layers/coils of 1" tubing as the heat exchanger, water filled. Within a week the pile would heat up. Many reaching 140 deg for months at a time
The idea was to circulate the water for heating purposes. This idea is used today to heat greenhouses and anything with radiant pipes. They are talking about large piles, as in several tri-axle dump truck loads. The Carbon to Nitrogen mix is key to get the critters breaking down the material, C/N 30-1. Carbon= wood products, Nitrogen horse, cow manure etc.
Done big enough, they can produce 15,000 Btu an hour. And some piles can produce for two heating seasons if timed correctly, i.e. start the compost pile in the fall.
The end result is heat and a big pile of compost for the garden. I've alway heard a tree rotting in the forest will make as much heat as the same tree burned in a wood stove
I have radiant heat and when I had it installed, I had them design a alternative heat source, for example solar. The main valves open to the alternative source if the source is 105 deg or more.
In any case, sounds cool if you live in an area where wood chips are free and delivered.
Welcome to the Compost Power Network | compostpower.org
