Compost Bins
   / Compost Bins #1
Airic
Indiana
GC2310
Anyone have some good ideas or pictures of a compost bin? I've got a lot of 1" x 6" pressure treated lumber from a friends old deck. Not sure if I should just build a three sided wall bin or if there are better ideas out there others have deployed. The other thing is that the location I have in mind does not get much direct sun. Is there any real issue with this in regards to the organic breakdown.
   / Compost Bins #2
i think treated lumber is not supposed to be used for organic compost bins.
if you turn your compost every couple of weeks it will break down the components very well whether in the sun or not.
   / Compost Bins #3
Do a goggle search and I'm sure there will be more plans and ideas than one can comprehend.:D
   / Compost Bins #4
A compost bin should have a volume of at least one cubic yard before the heat generated by the decay becomes effective.
I don't think that wood is a good idea.
I'd like to suggest building a three sided pen of five foot metal stakes and hardware cloth. I tried chicken wire and that didn't work too well. Three sided so that you can dump in there and also get in with a pitchfork to turn it over every three or four months. Your tractor bucket should do the trick in minutes.
I compost the autumn leaves to make my own soil.
Size wise. Simple math should convince you that building a big heap uses a lot less wall material than a small one. I use to have five heaps of a cubic yard each, then I consolidated and it's now roughly circular and about twelve feet across and three feet high. I have room for many years of leaves in there.
   / Compost Bins
Thanks for the info. I didn't know there was an issue with utilizing pressure treated wood. I'm assuming it can leach the chemicals. I'm having a hard time picturing hardware cloth, wouldn't seem to be very durable. I'm thinking of a permeate type bin. I was planning on building multiple bins in a row for different materials (i.e. stone, top soil, clay, sand, mulch and compost) All has accumulated in piles around the property from many of my project and I'd to get a little more organized. The compost bin has had me thinking it should be a little different set up. I could build block walls but that is a little more work than I would prefer.
   / Compost Bins #6
I am toying with the idea of making my mulch bin walls (and my compost as well) out of rammed earth tires. Google around on earthships and you will see what I am thinking.
I am thinking that the tire filled with wetted and packed red clay, overlapping each other with rebar through occassionally will be cheap, solid, durable, and able to handle the occasional bump from a loader. I am thinking along the lines of two tires side by side, stacked (interlocked) to about chest high.
   / Compost Bins #7
so alan, the rammed tire thing, basically tire with dirt "rammed" into the center hole? Hmmmmmm. I'll look at it some more. Sounds cool though!!
   / Compost Bins #8
Yes, the stuff I have seen they do it with a sledgehammer.
I am too fat and lazy to do that. :D
My current thought is to get some of the clay I am trying to get out of my pond, have a layer of tires in place, and dump with the clay in with the front bucket, then just soak it with a hose and kind of "wash" the clay into place.
One of my earlier thoughts was the HF Jack hammer
Harbor Freight Tools - Quality Tools at the Lowest Prices
and then make a domed head to go on it, do the dump slurry thing then "hammer" it in with that thingy.
I figure every couple of layers go down through every couple tires (real precise wording I know) with some rebar rods to kind of lock it all together.
My mulch beds are empty (mostly) at the moment and I am thinking of doing the center wall this way and see how it works.
As with many of my thoughts, it comes from having old tires to get rid of, and clay to get rid of, and extra Rebar lying about................. Has to be a wall in there somewhere :D
They had a thing on "invention Nation" where they showed it pretty well Episode of "Desert Power"
Episodes: Invention Nation : The Science Channel
When I was in middle school,,,, (Man, that was a tad bit ago 77 or so) Had this great teacher that was very alternative type lifestyle. We did tire walls etc. with him.
   / Compost Bins #9
wish I could find some old "PSP" -- steel sections with holes in it that we used in SEA for temporary flight line .... and anything else it came in handy for.
   / Compost Bins #10
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
SET OF (3) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (3) ALCOA...
TEST YOUR BID BUTTON! (A54756)
TEST YOUR BID...
2005 BIG TEX 18 TANDEM AXLE TRASH TRAILER (A53843)
2005 BIG TEX 18...
