Completely homemade excavator
   / Completely homemade excavator #1
snowb
Quebec
Home Made
Finally field trials.
Good lift, good stability, the shoveling speed is infinitely adjustable (0 to 12 GPM) and I was working around 5.5 GPM. There is no blind spot.
No sound of vibration or friction, the sources of are potential interference were numerous. Only the roof at maximum speed can vibrate. At maximum speed, there is 18GPM so when going up a hill, the engine is at maximum. At worst, we can lower the flow. The button on the right level adds 6GPM on the pull-only circuit, very handy for backing up quickly after pushing off dirt. It is necessary the ground was smooth much going to 6km / h, because on the rocks its breaststroke.
A defect of HDPE plastics in panels, it expands under heat, so it has ripples. But they're fixed securely enough thumb to stay in place and come back straight when the heat is off. I put a temperature sensor on the head of the engine so I can check if the motor is at a comfortable temperature.
The push force is greater (2800lbs / ft at the tracks) than on my previous excavators. It can pull out some roots while moving forward with the scraper. When its strength is a lot, it is because the scraper takes a small slice in the compacted soil under the loose earth. The handy side-tilting blade (commercial excavators rarely have this)
It is very pleasant to be able to move forward and backward on your path with the tracks, it compacts the soil without damaging it. The tracks were larger than a commercial excavator of the same weight, it sinks less. But it would still be too heavy for muddy flooded terrain, in which case you would have to work backwards.
Build picture and specification here: Completely homemade excavator
   / Completely homemade excavator #3
That thing is sweet , I can’t believe what thought and engineering went into that , I wouldn’t even know where to start , nice build, Dan
   / Completely homemade excavator #4
Congratuations on your build. It's a thing of beauty.
   / Completely homemade excavator #5
Well, I made one but didnt go for the fancy look! You did a great job on yours!
   / Completely homemade excavator #6
Very well done. It should serve you well. I wish I had the talent and the motivation to build something like this. Thanks for sharing.
Thanks!
   / Completely homemade excavator #8
Very nice!
Would like to see some details of the Tracktor bike, too. (y)
Thanks!
Tracktor bike
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
19200 (A50324)
19200 (A50324)
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
