Compatible attachments
/ Compatible attachments #1
cayote1
Buffalo New York
Kubota BX2230
I have a Kubota BX2230. Can I use a 7ft. box blade on the 3 Pt. hitch? Or do I have to stick to a 4 ft. blade?
Thanks Ya'll!
/ Compatible attachments #2
Can you? Sure if your moving dry sawdust around:laughing:
But seriously, a 7' box blade on your tractor will not work, its just to big.
/ Compatible attachments #3
If you take much of a bite, that's gonna be too much blade for the tractor. The BX being relatively light, you'll spin the tires before you run out of power.
I have a 5.5 I use behind my B2650 and if I'm taking a good cut it's all she wants for both power and traction.
/ Compatible attachments #4
You would be popping a wheelie , it wouldnt lift a 7 ft box blade
/ Compatible attachments #5
That 7' box blade would be using the BX as a front implement.
/ Compatible attachments #7
I doubt it would lift it, if it would, then you would need a full FEL bucket to keep the front wheels on the ground. You couldn't do much with it though even if you could lift it. A box blade can load up with dirt quickly and that is hard to move. I think you better stick with a 4 foot and even that will tax your tractors power and traction.
/ Compatible attachments #8
Box Blades, like most ground contact implements, rely on implement weight for cutting force.
Your most effective Box Blade will be the heaviest one per unit of width your BX2230 will pull using 4-WD, without spinning your tires. (See archive LINK.)
So shop for a Box Blade in either 48" or 54" width, as heavy as possible.
You will not find a 48" width Box Blade too heavy. You might find a 54" Box Blade so heavy that when loaded draft force will stop the tractor------but you can lift the Box Blade 1" and move forward once again.
Box Blades take longer to master than most new operators expect.
A Hydraulink Top Link helps considerably. Hydraulink also functionally helpful paired with Rear/Angle Blades and Landscape Rakes.
Hydraulink between tractor and most 3-Pt. implements provides shock absorption which I believe aided tractor longevity when I owned a Kubota B3300 SU.
No good with a Moldboard Plow.
VENDER LINK: Hydraulic Top Link Category 1, 2 x 8 Stroke | Agri Supply, 67464
T-B-N ARCHIVE LINK: http://www.tractorbynet.com/forums/...ta-b3300su-rollover-box-blade.html?highlight=
/ Compatible attachments #10
When I use a box blade on my 50hp I use a 7' and it can stop that tractor in the right circumstance, the BX won't do well with it.
/ Compatible attachments #11
No one mentioned this yet, but.... A 7ft blade is a serious BB and I would wager the 7ft blade is probably CAT 2 on the 3pt, but obviously his BX2230 is CAT 1. Of course, all the other answers are spot on!
Yeah I kinda figured these answers. But I just wanted to be sure. I saw a nice clean box blade for $495. Not a bad price? It would make a great counter weight.
It's a 4 footer.
/ Compatible attachments #13
I have a 4' KK and no t-n-t. Sometimes manual adjustment is hard enough from the weight of the 4', not sure I'd want the extra weight of the 5'. BB can be used with much more finesse when you figure it out, so small works well.
/ Compatible attachments #14
Totally agree! is the 7 footer a cat 1 or cat 2 ?
/ Compatible attachments #15
It's a 4 footer.
Try to determine the weight of the Box Blade. There are a lot of 48" Box Blades too light to cut tough dirt.
A 48" Box Blade should weight 400 pounds to 500 pounds to be effective.
Box Blades are excellent 3-Pt. ballast.
2021 PETERBILT 367 (A67714)
2021 PETERBILT 367...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2016 Chevrolet Impala Limited Sedan (A66738)
2016 Chevrolet...
SERVICE BED FOR TRUCK (A67714)
SERVICE BED FOR...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A66734)
2025 Swict 78in...
2025 CATERPILLAR 285 SKID STEER (A65056)
2025 CATERPILLAR...
