DayDreamer
Bronze Member
- Joined
- May 13, 2004
- Messages
- 52
I'm down to the final days before buying. Please review the attachment which shows the differences between models. The comparisons between back hoe and loader are below:
Manufacturer: John Deere
Model Loader: 300CX
Lift capacity (pivot): 1598 lbs
Lift capacity: 1122 lbs
Model Backhoe: 448
Digging force using
Bucket cylinder: 3730 lbs
Digging force using
dipperstick cylinder: 2435 lbs
Digging depth
2 ft bottom: 105.0 in
Manufacturer: Kubota
Model Loader: LA403
Lift capacity (pivot): 1091 lbs
Lift capacity: 783 lbs
Model Backhoe: BH75
Bucket cylinder: 3339 lbs
Digging force using
dipperstick cylinder: 2097 lbs
Digging depth
2 ft bottom: 91.0 in
Currently, the JD quote is $5100 higher than the Kubota. My questions:
1. Are the spec differences worth more money?
2. If so, how much?
The main use will be for installing approximately 300 feet of retaining wall with heights from 4 to 12 feet. Lot is sloped at a 45 degree angle that will need to be terraced. There are around 30 tree stumps that will need to be dealt with along the way.
I started this project out with an Orange hat, but, I think maybe it’s turning Green. Help….
Model Loader: 300CX
Model Backhoe: 448
Digging force using
Digging force using
Digging depth
Model Loader: LA403
Model Backhoe: BH75
Digging force using
Digging depth
2. If so, how much?
