Comparison Comparing L2800 / L3200
   / Comparing L2800 / L3200 #11
The L3200 ....................... It has the newer loader, LA524 if you are looking into getting a loader. The LA524 is somewhat stronger than the older model which is the LA463.
I would have to argue this. I believe that Kubota went the way of John deere and changed the point of measurement for their specs, for example; the LA 403 became the LA504. This does not make the loader stronger. Just wanted to clear that up and take it out of the equation for deciding. Plenty of other legitimate factors to consider. This has been mentioned in other threads earlier this year.
You did mention some valid differences that may help the OP.:)
   / Comparing L2800 / L3200 #12
There weren't many weak areas in the older L models, however they could stand improvement in a couple of departments, one being the smoothness (or lack thereof) of the 3 ph raise function.
I like the dash on the old tractor, the new one not so much.
Sean
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2015 Ford F-350 4x4 Service Truck (A59230)
2015 Ford F-350...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
Zero Turn Mower (A59231)
Zero Turn Mower...
