Compact tractoring on the cheap!?
/ Compact tractoring on the cheap!? #61
The other countries around the world mostly use their tractors for tillage work. Hydro's will not last as long as gear types when used for tillage operations. Also they cost a lot more to repair and require a higher skill level, etc. You can't beat a grar driven tractor for relaibility, power transmission, and ease of repair.
Here in the US many of these smaller (CUT) tractors are used for mowing and loader work, Hydro works ok for this. I think if a study was conducted you would find similar statistics on automatic transmissions in autos, for most of the same reasons.
We Americans are fairly lazy ( self included ), and don't see why we should have to push a clutch when we don't have too. And are willing/able to pay for the increased maintenance costs.
/ Compact tractoring on the cheap!? #62
<font color="blueclass=small">( <font color="blue">Hydro's will not last as long as gear types when used for tillage operations) </font>
How do you figure that ? /forums/images/graemlins/confused.gif
( <font color="blueclass=small">( <font color="green"> You can't beat a grar driven tractor for relaibility, </font> )
Is a hydro not as reliable or durable ??
How so ?
/ Compact tractoring on the cheap!? #63
I don't necescarilly think one is 'better' than the other... but more that they are better at different tasks.
For instance.. those that use a loader unanimously agree that a hydro is the way to go. On the other hand, if you plow and disc all day long.. gear is the way.
The differences? A gear tranny converts nearly all engine hp to the drive wheels. ( a small amount is lost in the drivetrain )
A hydro eats up a few hp in the fluid/pump /motor /torque converter ( if equipped ) setup.
Heavy long term tasks are going to wear on the hydro tranny more than the gear.. thus if you say.. plow dawn till dusk, for the same engine hp, a gear tranny is going to perform slightly better.
It is mostly a matter of application, personal taste, and economics. Hydros are a bit nmore expensive, and there are no real long term comparisons, as is with gear trannies.. for instance.. many people are happilly putting around on 9n tractors with straight cut gear trannes from 1939.. that's like 63 years.... In 63 years from the time when hydros started in use in tractors ( 70's?? late 60's? ).. we'll see how they fare..
I personally love a gear tranny... always have... and there are people on both sides of the fence..
Soundguy
/ Compact tractoring on the cheap!? #64
CountryBoy1,
A well built gear tranny will last virtually forever as long as you keep it full of good lube, and don't abuse it too badly. A Hydro transmission has O-rings and seals in them that will wear out/get hard and cause failure of the transmission. They also generate quite a bit of heat which contributes to this problem and causes the lube to break down sooner.
It is a bad feeling when a 2.00 O-ring breaks in the middle of a Hydro and you have to take the whole darn thing apart to change it. This is a reason for the increased maintenance/repair costs.
with all this said, Hydro's are pretty reliable, just not as reliable as a good gear tranny.
As Soundguy said there is also the HP loss thing with Hydro's. However they are great for loader work and mowing in tight areas.
/ Compact tractoring on the cheap!? #65
I know running a tiller the hydro is great and my brush hogging on the edges of the hollows where it is best to back in when you are mowing,the repetitive back and forward motion my hydro has spoiled me.
I wonder how the hydros hold up on the bulldozers ?
Are the hydros causing a lot of people problems ???
/ Compact tractoring on the cheap!? #66
The Dozers have a completly different type of transmission.
Egon
/ Compact tractoring on the cheap!? #69
I agree... Our largest dozers.. like our d-8 and d6-9u both are gear drive monsters... I think even our d-4 final drive is geared. Our jd loaders are torque converter, .. though, the manufacturer reccomends not to use them to tow or drag items as the tranny will overheat ( we found this out by using our loader to drag a large harrow across some property we were prepping for a road bed.. after a short time.. like 15-20 minutes.. tranny heat light came on... a quicj call to jd dealership confirmed this).
At our construction co. with all our various pieces of different equipment, we have been running about 40/60 on gear vs auto repairs.. by auto, I am lumping all the various types of auto trans and hydrostats, etc together.
While we have replaced quite a few ring/pignion sets.. we have done just a bit more work on the hydro's.. Prices / dificulity of work on the hydro's was a bit higher.
In the end.. neither repairs were cheap!
Soundguy
/ Compact tractoring on the cheap!? #71
</font><font color="blue" class="small">( ( I agree )
What are you agreeing to ? )</font>
If you look at the subject line of my message, it says re: Egon... the message right above mine was from Egon.. he stated that the 'big yellow ones do.. etc.. etc..
Soundguy
/ Compact tractoring on the cheap!? #72
</font><font color="blue" class="small">( The big yellow ones don't. )</font>
You are agreeing with Egon that the big yellow ones do not have hydrostatic transmission? But they do have hydrostatic transmissions available is what I am saying.I operated a John Deere 750 in 1986 with hydrostatic drive.
/ Compact tractoring on the cheap!? #73
I think Egon and myself are refering to the large 'heavy' equipment.. like 544g, 644, etc... And while some do have an auto trans.. it is radically different than the hydro on our tractors... most of our units use a torque converter. Some even use the pump and independent motor design. So many differences..
Soundguy
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
Headsight Autopilot Kit for Claas (A63117)
Headsight...
2006 John Deere 120C Hydraulic Excavator (A61572)
2006 John Deere...
LANDPRIDE FDR1648-48" FINISHING MOWER (A64280)
LANDPRIDE...
