compact tractor post pounders???
/ compact tractor post pounders??? #1
stubbornrichard
i was looking at some small post hole drillers for my b7100 kubota and started thinking if it was possible to put a small post pounder on it instead, i was wondering if anyone has attemted this or could put me in the right direction, thanks!!!!!
/ compact tractor post pounders??? #2
I put one on a B7100 (gear) approx 29 years ago. I believe it was a Danuser, not sure if it's even still made. Worked a hydraulic motor (off the FEL hydraulic pump) which engaged the 350# weight column with a friction rubber wheel to raise it, then drop. Pretty effective, drove a post so tight that sometimes I couldn't pull it out with the FEL.
The cons were several:
!. The B7100 is a pretty small tractor to be hauling an attachment that heavy and TALL (it occasionally got pretty scary in hilly terrain).
2. The soil out here varies a great deal from extremely hard, (hard pan) to glacial till liberally laced with various size rocks which all conspire to deflect the post out of plumb.
3. As I recall, I had to modify the post drivers attachment system considerably to allow more and easier adjustment to plumb the driver on hilly terrain.
4. It was a bit nerve wracking to hook up and unhook and store because of the overall weight and top heavy nature of the beast.
5. For better or worse, it wouldn't work in the rain, because the lifting "tire" would slip on the weight column.
6. I don't think I ever drove a steel "T" post with it because by the time I could have it aligned to start driving, I could have driven two or three steels by hand.
Other than that, I loved it :D We installed lots of fences together.
Although, if I had it to do over, I might seriously consider other options.
Hope that helps
Regards
Sherweld
Thanks, yea that does help alot i was thinking of even buying one and putting an axle on it then hook it to the ball hitch, so basically make it a tow behind to take the load off the 3 point hitch, another option is to simply make my own with some kind of heavy weight that i can raise and drop quickly, i had fun making other 3 point hitch attachments so this might just be the project for the winter.
