Compact Tractor Newbie - Whats the appropriate attachment?
   / Compact Tractor Newbie - Whats the appropriate attachment? #1
tractorslt
western, massachusetts
Mahindra Max 28 w/ Loader
So im new to the tractor scene, and i recently purchased about 30 acres of raw, wooded land. I recently purchased a 28 hp sub compact tractor with a class 1 3pt hitch. A section of the land was partially logged 15-20 years ago, and I'm looking to open up a 1-2 acres food plot. My plan is to drop/clear the tree's, and work around the stumps(which are spaced pretty far apart) for the time being. My question is: What is the best attachment to use to break the soil that has roots/occasional big(2-3') rocks? Or, atleast, what attachment would I start with?
Thanks.
   / Compact Tractor Newbie - Whats the appropriate attachment? #2
Racket rake would do that assuming you have a loader.
   / Compact Tractor Newbie - Whats the appropriate attachment? #3
Welcome from Wisconsin
   / Compact Tractor Newbie - Whats the appropriate attachment? #4
Ratchet Rake is an excellent attachment for tearing out brush but time consuming for scratching up two acres of ground prior to seeding.
Most often a Disc Harrow is used to open the dirt for food plots, then the ground is seeded, then seed is rolled in with a Cultipacker.
Your Max can't quite handle an Disc Harrow with 18" pans, the minimum weight required to cut the surface, and rocks eliminate a PTO powered roto-tiller, so I recommend a Tufline 2/22" Disc Plow.
Used Disc Plows show up regularly on eBay, Ken Sweet, Sweet Tractors in Kentucky, being reliable. You do not want too heavy a Disc Plow for the Max.
An alternative would be any of numerous "No-Till" food plot mixtures, based on clover. Clover seed is very small and is NOT rolled in.
Rolling in most seed for good ground contact/adequate moisture take-up, is important, Clover being an exception. Do not seed until rain is forecast. An improvised drag will do, a roller is better; a Cultipacker is best.
NOW is the time to plant a winter food plot at the higher elevations in Massachusetts.
LINKS:
http://www.ratchetrake.com/images/ratchet_rake_brochure.pdf
http://www.tractorbynet.com/forums/kubota-owning-operating/146060-ratchet-rake-ever-seen-used.html
http://www.monroetufline.com/pdf/TDP Discplow (47990).pdf
Everything Attachments Cultipacker 5' with smooth wheels
So maybe just a rake to clear debri/scratch up the soil would be better for a no-till plot?
   / Compact Tractor Newbie - Whats the appropriate attachment? #6
Your tractor may mash up the ground enough as you remove trees to make No-Till a reasonable proposition with no other prep. Cleaning up is certainly better.
You can plow in the late Winter then plant a Spring/Summer grain mix after final Spring frost.
In Florida, Ace Hardware and Southern States Co-ops are good sources for low price 40-50 pound bags of food plot seeds. Walmart has seed on a hit-or-miss basis, in Sporting Goods. Clover is a premium price.
Many web venders but freight increases net cost.
   / Compact Tractor Newbie - Whats the appropriate attachment? #8
A Ratchet Rake on your bucket will work better for piling/moving debris than a Landscape Rake on the Three Point hitch.
Yea, i took a look at a couple of youtube videos on a ratchet rake. It might be my best bet to get one and keep it simple with a throw n grow/no till type seed...and maybe line the area with some apple trees. Thanks for the input guys.
250 GALLON FUEL TANK (A51247)
250 GALLON FUEL...
2023 LandHonor RB-14-72W 72in Rock Bucket Skid Steer Attachment (A51691)
2023 LandHonor...
2009 DRAGON  130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
20702 (A51694)
20702 (A51694)
Frontier GM1084 (A50123)
Frontier GM1084...
UNUSED WOLVERINE TL-12-72W - 72" HYD TILLER (A51248)
UNUSED WOLVERINE...
