Compact Tractor FEL Hydraulics
   / Compact Tractor FEL Hydraulics #1
jb92563
Bronze Member
Riverside, CA
Yanmar 240, 4' Box Blade, FEL, Rice & Turf tires
I have a couple questions about rebuilding the pistons on my YM240's unknown aftermarket brand FEL. (I'm a complete Hydraulics servicing novice)
It seems to have a wire lock securing the gland. What is the proper name for this wire when I contact a hydraulic shop to describe it?
I also assume that they are for one time use and need to be replaced every time I take the gland off?
For the short flexible hydraulic hoses on the FEL between the metal hydraulic piping and the cylinders, how does one remove/attach them?
Are both ends unscrewed/screwed together in the same direction so that the hose does not get twisted up.
That would mean that one is a left thread to loosen and the other a right thread to loosen?
Or is there another way to remove/attach a hydralic hose?
   / Compact Tractor FEL Hydraulics #2
A good hyd hose guy will put a fixed end on one end and a swivel fitting on the other end.
He should do what you ask.
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
2023 Kubota KX057-5 Compact Excavator (A55314)
2023 Kubota...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
