Compact Tractor FEL Hydraulics
   / Compact Tractor FEL Hydraulics #1
jb92563
Riverside, CA
Yanmar 240, 4' Box Blade, FEL, Rice & Turf tires
I have a couple questions about rebuilding the pistons on my YM240's unknown aftermarket brand FEL. (I'm a complete Hydraulics servicing novice)
It seems to have a wire lock securing the gland. What is the proper name for this wire when I contact a hydraulic shop to describe it?
I also assume that they are for one time use and need to be replaced every time I take the gland off?
For the short flexible hydraulic hoses on the FEL between the metal hydraulic piping and the cylinders, how does one remove/attach them?
Are both ends unscrewed/screwed together in the same direction so that the hose does not get twisted up.
That would mean that one is a left thread to loosen and the other a right thread to loosen?
Or is there another way to remove/attach a hydralic hose?
   / Compact Tractor FEL Hydraulics #2
A good hyd hose guy will put a fixed end on one end and a swivel fitting on the other end.
He should do what you ask.
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2020 FREIGHTLINER M2 26' BOX TRUCK (A57192)
2020 FREIGHTLINER...
UNUSED IRGC40 MINI ELECTRIC GOLFCART (A57193)
UNUSED IRGC40 MINI...
2020 International MV607 16ft Morgan Dump Truck (A55852)
2020 International...
2011 Kenworth T7 Series (A55973)
2011 Kenworth T7...
Selco V5-HD Vertical Hydraulic Baler (A55851)
Selco V5-HD...
