Spreader Compact Seed and Fertilizer Spreader /3 pt lift
   / Compact Seed and Fertilizer Spreader /3 pt lift #11
Re: Compact Seed and Fertilizer Spreader /3 pt lif
Beekeep, the M96 can be used on any tractor with a 3 point. It is avaialble with an extension for the hopper. Herd also makes several larger units. Recently, Nuru, turbo 4100, purchased a nice spreader but I forget the brand. Maybe he will chime in. Hey, Nuru, my 2410 will smoke your turbo 4100. Zero to 8 MPH in two seconds. /forums/images/graemlins/grin.gif J
Intend to use on KOBOTA B2400 HST
   / Compact Seed and Fertilizer Spreader /3 pt lift #13
Well, you might check and see that I use my M96 on one of dem dar Kobotas 2410s /forums/images/graemlins/wink.gif. J
   / Compact Seed and Fertilizer Spreader /3 pt lift #14
Probably just a dumb question: Some one told me that if you use these cone type spreaders for spreading a seed mixture that certain seeds (depending on there size) will sift right to the bottom as you bounce along. Clover seed is much smaller than grass seed, so I could see how that might happen. Then all your clover would end up in one spot. Anyone know about this problem.
   / Compact Seed and Fertilizer Spreader /3 pt lift #15
I have not found that to be a problem but usually I spread my seed types individually. I have four acres of Broam, Alfalfa and Red Clover. I seeded them individually. J
   / Compact Seed and Fertilizer Spreader /3 pt lift #16
It wasn't a problem when I've used one.
   / Compact Seed and Fertilizer Spreader /3 pt lift #17
I have used the Herd Seeder M96 for fertilizer and grass seed, I have never used it for a mix of any kind but I have never had any trouble with the product moving to one side. Unless I am on my side hill and it does tend to create its own level somewhat then.
murph
   / Compact Seed and Fertilizer Spreader /3 pt lift #18
If you are interested what the extension looks like on the Herd Seeder M96, here is a picture. It adds 16 inches to the height and is 21 inch across the top. I can see already I will need to attach it in a way that I can remove it easily to get to the base to measure the opening gate and grease the fitting. I am way to short to reach the bottom.
/forums/images/graemlins/mad.gif
   / Compact Seed and Fertilizer Spreader /3 pt lift #20
barticus73,
Yes they will, salt and sand too but you'll want to wash it out or get the unit with the poly hopper it you'll be doing alot of salting.
You may also want to note the TSC cone style doesn't have the fine metering capability of the Herd so I don't recommend it for seeding.
Enjoy,
Michael
Killbros 260 Seed Conveyor (A57024)
Killbros 260 Seed...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A56138)
2019 INTERNATIONAL...
2002 CATERPILALR D8R HI-TRACK CRAWLER DOZER (A52707)
2002 CATERPILALR...
2012 Mazada 3 Sedan (A55853)
2012 Mazada 3...
