Compact 990 Hydraulic issues
/ Compact 990 Hydraulic issues #1
danabcraig
John Deere 990
I have a 2007 990 compact tractor and the hydraulic system is driving me crazy. It was working fine then started getting jerky and then quit. I've lost all both steering and other functions. When I checked the screen was clogged so I replaced the screen, filter and new hydraulic fluid. It still didn't work, It appears to be starvine for fluid at the pumps so I primed them, it worked until it used up the prime. Checked/replaced all of the rubber hoses as I found one was cracked. Then in desperation I replaced both pump and still it doesn't work. Cleaned the filter housing and made sure it wasn't clogged.
I'm at a loss on what to do. I got the hydraulic fluid from Tractor Supply, I thought it said J20 compatible, could this be the issue?
/ Compact 990 Hydraulic issues #2
J20C marked on the TSC Universal hydrostatic fluid should be fine.
Is there air trapped in the system?
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
Mayrath 10" x 34' Truck Auger (A66285)
Mayrath 10" x 34'...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
Farm Hand Silage Wagon (A65640)
Farm Hand Silage...
