Common to leak oil axle if over-filled?
   / Common to leak oil axle if over-filled? #1
QuasarZ
Western WI
Previous Branson 2400H. Looking for new
I just drove my tractor about 5 miles round trip to get some bucket hooks welded on and when I got home I noticed it was wet on the front right axle by fill port. I checked the level and it is right on the mark. Could it have been too full from the factory and it just worked its way to the correct level?
   / Common to leak oil axle if over-filled? #2
Possible, clean it off and see if it still continues to leak there.
   / Common to leak oil axle if over-filled? #3
5 miles of road travel? Depending on speed and bouncing around it might splash out of the breather hole. Could have built up some pressure due to temperature. Some tractors have the breather hole drilled into the fill cap. Some have a separate tube the runs up a foot of so to keep water out of the diff/axle gearbox. If it has a separate breather tube there should not be any fluid near the fill/check plug unless it isn't sealed (gasket?) or the breather tube is blocked or pinched off.
The other reply us correct. Clean it up and watch it.
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
Brent 776 Grain Cart (A50514)
Brent 776 Grain...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
Killbros 385 Gravity Wagon (NICE) (A50774)
Killbros 385...
2004 TAKEUCHI TB175 EXCAVATOR (A51242)
2004 TAKEUCHI...
2017 Kia Optima (A50324)
2017 Kia Optima...
