common tires on compact tractors
   / common tires on compact tractors #1
4tillingdirt
nc
N/A
I was looking at some different tires and noticed that 17.5l is wider but about 3 inches less in diameter and 7 inches less in circumference than the 16.9. I was looking at firestone site - All Traction Utility R-4 Tire - Firestone Commercial
Is this pretty common that the 16.9 is that much larger around and would you prefer the 17.5 because it would have the tractor riding lower- less tippy perhaps? I noticed the larger LS XR series use the 17.5l.
   / common tires on compact tractors #2
Ah - well - I guess your question is in regard to no specific tractor. For added stability - on my M6040 - I have widened the front and rear tire stance and added Rim Guard to the rear tires. Its very important that the proper tire size ratio is maintained - front tires to rear tires - if you are talking 4WD.
Actually - in a situation where you are in a state of unbalance - the height difference between the 16.9 vs 17.5 - is going to provide an added safety margin, only in your mind. You best not rely on the difference in height between those two tires - you better do something pro-active and RIGHT NOW or you are on your way over.
   / common tires on compact tractors #3
Thats what the L stands for.
Low profile
So yes, its common.
Car tires have THREE units of measurement. Width....sidewall height / diameter / aspect ratio......and rim diameter.
Tractor and industrial tires have 2....just width and rim diameter with no designation for height. But it is pretty standard.
The L is a designation for a low profile tire. A 19.5L tire is about the same as a 16.9 standard tire. So if you want width at the same height....gotta jump to the 19.5L's.
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A53426)
2004 TRAVIS 48'...
2024 JOHN DEERE 461M LOT NUMBER 60 (A53084)
2024 JOHN DEERE...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (INOPERABLE) (A52472)
2017 PETERBILT 567...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
