Commercial Walk Behind Tire Lifespan
   / Commercial Walk Behind Tire Lifespan #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I am curious how long a 48 in commerical walk behind mower rear tires will last.
I have a similar sized machine, that makes similar turns. I would like to foam the tires, but I would like the Carisles to last a while.
   / Commercial Walk Behind Tire Lifespan #2
I usually get around 3000 hours before they are bald. Always get 4ply
   / Commercial Walk Behind Tire Lifespan #3
It mostly depends on operator and numerous other variables. Whether you are 3-point turning or doing a zero turn and scrubbing tires. Large yards with long runs between turns, or small yards where you are making a 180 degree turn ever 50' pass. how much pavement or sidewalks? I service a dozen or so mowers for a local landscaper, and about 1000hrs per set is the norm for them.
Thanks guys! I have plenty of 150 ft strait runs, but I also have a few obstacles.
   / Commercial Walk Behind Tire Lifespan #5
i loaded both ft & rear tires on my 36" zero walk behind...the loaded front gives some ballast with tight turn arounds on slopes, less likely for ft end to rear up
2023 Case-IH 280 Magnum (A50120)
2023 Case-IH 280...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2016 Ford E-350 Enclosed Service Transit Van (A50323)
2016 Ford E-350...
2018 John Deere 460E Articulated Dump Truck (A52748)
2018 John Deere...
Surfer Z (A50121)
Surfer Z (A50121)
