Commercial Walk Behind Tire Lifespan
   / Commercial Walk Behind Tire Lifespan #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I am curious how long a 48 in commerical walk behind mower rear tires will last.
I have a similar sized machine, that makes similar turns. I would like to foam the tires, but I would like the Carisles to last a while.
   / Commercial Walk Behind Tire Lifespan #2
I usually get around 3000 hours before they are bald. Always get 4ply
   / Commercial Walk Behind Tire Lifespan #3
It mostly depends on operator and numerous other variables. Whether you are 3-point turning or doing a zero turn and scrubbing tires. Large yards with long runs between turns, or small yards where you are making a 180 degree turn ever 50' pass. how much pavement or sidewalks? I service a dozen or so mowers for a local landscaper, and about 1000hrs per set is the norm for them.
Thanks guys! I have plenty of 150 ft strait runs, but I also have a few obstacles.
   / Commercial Walk Behind Tire Lifespan #5
i loaded both ft & rear tires on my 36" zero walk behind...the loaded front gives some ballast with tight turn arounds on slopes, less likely for ft end to rear up
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
2016 John Deere Gator XUV560S4 4x4 Utility Cart (A50322)
2016 John Deere...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
Gehl 2580 Round Baler (A50774)
Gehl 2580 Round...
