Commercial Use?
   / Commercial Use? #31
All, let me try to put it all in practical, not legal terms. A tractor with backhoe and/or loader for example can be used to dig a hole for a swimming pool or pond, help clear land on your property, move dirt or gravel, dig out stumps, etc. But doing that every day for a living can take the duty cycle to extreme limits for a tractor, and is better handled with construction equipment, which is inherently commercial by design and use. Our warranty statement is meant to address that distinction, and the wording we use is based upon industry precedent, not anything unique. In other words, dig your pond with a tractor, but if you dig ponds for a living, get an excavator, or accept a reduced warranty period. Hope that helps.
   / Commercial Use? #32
That appears to be what we've been saying. So, in the example given, the contractor using it on sites of homes being built WILL have coverage for the first two years, correct?
Still suggest the warranty policy page to be edited to be more clear.
   / Commercial Use? #33
So... where do you draw the line? How much is too much? Are you a contractor that uses his machine every day? Or are you a small business that uses it occasionally? Can you use it in a landscaping business, where you need to move around mulch in flower beds or the backhoe in building retaining walls? What if your neighbor asks you to dig a drainage ditch and offers to pay you for it? Is that commercial? Does it void, or limit your warranty? What about Outdoors with the Morgans? Mike uses his tractors for "forestry operations". Logging his woods, for firewood that he sells. Does that limit the warranty? It all seems a little vague and cloudy. It's easy to see the extremes in either direction, but what about the gray areas in between? And I suppose this is an true of any tractor with a warranty, not just RK.
   / Commercial Use? #34
A farmer uses a tractor for farming, which is his business, a commercial operation. Farmers get the full warranty. No one would say that commercial farming would be excluded. Logging is not Mike Morgan cutting firewood and selling some of it. The gray area is divided by common sense. Warranty policy is inherently a bit cloudy, there are inclusions, exclusions, responsibilities of the manufacturer and the customer. The real measure is when the customer believes that they are being taken care of. Citing things like paving, demolition, logging as industries is applying a little of that common sense before the purchase. As you say, every brand has language like that in its warranty statements and the tractor business has rolled along fine with it for a long time. The best advice I can give to anyone comparing warranties is to look at duration, for any deductibles, if both parts and labor are included. RK has the longest powertrain warranty, no deductibles, parts and labor included for all years covered. If anyone can find any other tractor brand with an 8 year powertrain warranty, please share it.
   / Commercial Use? #35
I appreciate that! Also one of the reasons (among many) that I chose RK. Any company that's willing to stand behind their products goes a long way with me. Common sense should go a long way. Seems to be in short supply these days. A hand shake should be enough but, sad to say, that's not as easy to find either. Thanks for weighing in.
   / Commercial Use?
It's probably worth noting that even for commercial use, the warranty is better than what others offer. Kubota for instance covers 2 years / 1500 hours for basic standard and 3 years / 2000 hours for limited powertrain for commercial operation. Both of those figures are less hours than covered by the RK warranty. That is something else for a prospective buyer to consider when cross-shopping. More tractor for your money and better warranty. How is that not worth a look?
   / Commercial Use? #37
Just curious if anyone on the board is using their RK tractor for commercial use? I have a friend who is a residential contractor that is looking at the RK37 for jobsite use. He needs something to move materials around the jobsites, dig the occasional footer or open up foundations for re-sealing. A mini-ex would be perfect for the digging, but it can't move a pallet of brick, level a backfill or spread gravel. The payment on a fully loaded RK37 is less than he is paying in repositioning fees to have equipment on site for those types of jobs. Is anyone out there using an RK in daily commercial use?
I'm late to the game since your friend has already ordered his tractor. I'll throw in my 2 cents anyways.
Assuming your friend operates it with common sense that tractor is going work well for him. Versatility with a reasonable price tag is a key to reduce over head in a small business.
Sure, dedicated construction equipment will move more dirt and last longer. A small business can't always afford the perfect machine for each job. And if they could afford it, add in the time and cost to move all that equipment around.
For your friends intended use it sounds right on. I bet he will wonder why he didn't buy something like this sooner.
   / Commercial Use?
I think the key there is that it is very versatile (look at all the construction related attachments available for SSQA and 3 point). The other major key is that heavier equipment can be rented or hired when needed, as he is currently doing. I think he will find that it will easily pay for itself. It isn't an excavator, but it can dig a respectable trench. It isn't a commercial loader, but it can move some material around. It is also the perfect tool to whip the lawn back into shape after that room addition is done. He's definitely going to wonder why he didn't buy it sooner.
   / Commercial Use?
Since it has been about a year I thought an update might be in order. The tractor has a few hundred hours on it now. The only part replacement has been the three way valve, which was damaged by a tree. The owner said it took some fussing to get the store to finally order the part for him, but the warehouse shipped it right away after he finally got them in gear. The normal service has been done by a local heavy equipment service shop. They are much closer than the store and have quick turn-around. They have had no issues getting filters, etc.
The owner is very happy with the tractor and it's abilities. Of the backhoe he said that although it's reach won't compete with an excavator "It will dig!". He figures the foundation work he did on his own house would have involved at least $30K in excavation costs, so as far as he is concerned it has already paid for itself. He has also done several other foundation jobs for his customers, which the RK37 was able to handle. It has proven to be very useful on the job site. He sometimes wishes he had bought the RK55, but then it would require an HD pickup to tow, where the RK37, even with the backhoe mounted, can be towed behind any of his trucks. It also fits into places the RK55 wouldn't.
One concern he ran across was with the canopy. The fastening system allowed it to be knocked loose by tree limbs. That presented an issue because the tractor is regularly towed on highways and he was concerned it could come loose in transit and hit a car behind. A couple of U bolts were added to securely attach the canopy to the ROPS.
Overall the RK37 has done exactly what he wanted it to do with basically no fuss. He no longer has to wait days for a sub to show up to dig a hole. Money well spent.
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
City of Ft. Lauderdale 59,898 miles. Year: 2023 Make: Chevrolet Model: Tahoe Vehicle Type: (A56859)
City of Ft...
2017 Ford F-350XL (A57148)
2017 Ford F-350XL...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
1625 (A58375)
1625 (A58375)
(INOPERABLE) GEHL 8K TELEHANDLER (A58216)
(INOPERABLE) GEHL...
