Rotary Cutter Comments on Bush Hog Razorback cutter
   / Comments on Bush Hog Razorback cutter #1
shaley
Platinum Member
Tidewater VA.
Ford '92 2120
I'm looking at a used Bush Hog Razorback 60" cutter. Are there any known weak spots to look for. I notice this cutter is in the economy range with a shear pin only and no clutch. I'm just using it for a small yard area.
   / Comments on Bush Hog Razorback cutter #2
For many this unit is fine and there have been no problems with those we have sold.
The shear bolt vs slip clutch is equal ground for many. You will mostly be mowing the same piece of ground so shear pins will work fine as long as you learn where it hit's things and you need to take evasive action or to remove them.
   / Comments on Bush Hog Razorback cutter #3
I am a Bush-Hog fan..have their brush-hog,seven foot rear blade,tiller and box blade..the brush-hog (purchased new) has about 500 hours on it;beat up but still works fine; I have only broke two shear pins.I much prefer shear pins to clutches in a brush-hog.:thumbsup:
   / Comments on Bush Hog Razorback cutter #4
I'm sure Art knows what he is talking about but...
If you live in I give my slip clutch a work out every time I cut my pasture. The ***** gophers pile up a lot of dirt where the weeds are tall and I would be poping pins left and right.
2016 Peterbilt 567 Tri-Axle Dump Truck (A50323)
2016 Peterbilt 567...
2012 WABASH 53FT DRY VAN TRAILER (A52141)
2012 WABASH 53FT...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
Case IH Precision Disc 500T (A50120)
Case IH Precision...
