muddstopper
Veteran Member
Easy answer, just get a pump with proper flow. Never one to do things the easy, or smart way, so here is the question. I have two identical pumps, same brand, same flow, same pressure. Neither pump is big enough by itself, but together they would provide the correct flow rate. Whats the easiest way to combine the flows to run just one circuit. Is it as simple as just tee the pressure lines together and then run one line from the tee to the control valve, is some type of check valves needed, should each pump have its own relief plumbed in before the tee. Yes, I know, one pump of the correct size is the best way to get the flow, but I dont have the right size pump, and I do have the 2 smaller pumps and I'm trying to utilize what I have on hand before trying to source more parts.
