Colored Roof Coating?
/ Colored Roof Coating? #1
scesnick
Veteran Member
Garrett County Md. ( Western Md.)
Kubota MX5100
Thanks to the wonderful 40yr shingles that lasted only 10 yrs, I now have a roof leak. I plan on replacing the shingles with a metal roof next spring but for now I need to get this roof to stop leaking.
I know about where the leak is, but I can't pin point it and frankly I'm sick of looking for it.
I would like to find a roof sealant to cover a faily large area ( 10'x10') that should easily cover the leaking area.
But, it is a evergreen colored shingle that is highly visable and would need some type of colored sealant to match so it doesn't look terrible.
Any ideas where I can find it? I have looked for quite a while and can only find white and black.
BTW- stay away from TKO inc. shingles thay are total trash and they will not honor their so called warranty.
/ Colored Roof Coating? #2
I would just get a bundle of the shingles you have and take up a 10x 10 area and replace. That is what i did on my roof when i could not pinpoint exactly where it was to get it , now my roof is well older than that and needs to be replaced i just dont have the $ to redo it now.
The roof leaks are hard cause they can leak feet away from where they actually penetrate your inside, due to tar paper then going in a nail hole then following the roof sheating till a joint. My roof has 1x6 boards so they cant travel as far once under the paper as a plywood or OSD decked roof would.
Sorry if this has been mentioned i hit reply then went out on the boat and now have returned to post my thoughts hours later.
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A64194)
John Deere 12in...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2025 Swict 84in. Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
UNUSED WOLVERINE TDB-11-84W-84" BUCKET (A64281)
UNUSED WOLVERINE...
