Color of fluid on rearend (hyd.) on 4100
   / Color of fluid on rearend (hyd.) on 4100 #1
acs55812
Duluth, MN
When checking over the tractor just after removing the loader I noticed the fluid on the hose coupling looked a little cloudy, in checking the dip stick I noticed its a pinkish fluid but its not a good clear pink---its cloudy as if it may have moisture in it. Could this be the result of 5 years of condsenation? If so is there possibly a synthetic fluid I should consider replacing it with?
Thanks
Dan
   / Color of fluid on rearend (hyd.) on 4100 #2
Sure sounds like water in the hydraulic fluid. I never thought of hydraulic fluid being hydroscopic...but one can get water in oil (engine type) and be frothy.
Probably a good time to flush out your system and renew the fluid.
   / Color of fluid on rearend (hyd.) on 4100 #3
Don't know your storage or useage conditions, but five years is too long for HST tranny oil to be un-changed. If it's red or pink, it's probably still the oil that was in there when it left the dealership.
   / Color of fluid on rearend (hyd.) on 4100 #4
Smacks of water, and possibly anti-freeze. Not sure if there is a potential for antifreeze getting in the fluid, but either that (any loss of antifreeze?) or someone mistakenly put antifreeze in instead of hyd. fluid.
   / Color of fluid on rearend (hyd.) on 4100 #5
</font><font color="blue" class="small">( Could this be the result of 5 years of condsenation? If so is there possibly a synthetic fluid I should consider replacing it with?
Thanks
Dan )</font>
WOW 5 YEARS? /forums/images/graemlins/shocked.gif
Like Pete said, the red fluid is used at the factory on the Yanmar produced tractors, so you probably have the origanal fluid in there.
How many hours are on this machine?
I would change that fluid and hydro filter ASAP, I use the JD branded fluid in mine, so cannot comment on a synthetic product
184 hours---Almost has to be water, antifreeze is nowhere near the hyd. fluid.
   / Color of fluid on rearend (hyd.) on 4100 #7
Re: Color of fluid on rearend (hyd.) on 4100 *DELETED*
OK /forums/images/graemlins/wink.gif
Post deleted by beenthere
BEENTHERE----I edited my post to remeove confusion, no we are talking tranny on a gear model.
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
JOHN DEERE RC7 R LOT NUMBER 224 (A53084)
JOHN DEERE RC7 R...
Pallet of (6) 8 Lug Misc Wheels (A51573)
Pallet of (6) 8...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
(3) 55-Gallon Drums of Fertilizer (A51573)
(3) 55-Gallon...
