Color of fluid on rearend (hyd.) on 4100
   / Color of fluid on rearend (hyd.) on 4100 #1
acs55812
Duluth, MN
When checking over the tractor just after removing the loader I noticed the fluid on the hose coupling looked a little cloudy, in checking the dip stick I noticed its a pinkish fluid but its not a good clear pink---its cloudy as if it may have moisture in it. Could this be the result of 5 years of condsenation? If so is there possibly a synthetic fluid I should consider replacing it with?
Dan
   / Color of fluid on rearend (hyd.) on 4100 #2
Sure sounds like water in the hydraulic fluid. I never thought of hydraulic fluid being hydroscopic...but one can get water in oil (engine type) and be frothy.
Probably a good time to flush out your system and renew the fluid.
   / Color of fluid on rearend (hyd.) on 4100 #3
Don't know your storage or useage conditions, but five years is too long for HST tranny oil to be un-changed. If it's red or pink, it's probably still the oil that was in there when it left the dealership.
   / Color of fluid on rearend (hyd.) on 4100 #4
Smacks of water, and possibly anti-freeze. Not sure if there is a potential for antifreeze getting in the fluid, but either that (any loss of antifreeze?) or someone mistakenly put antifreeze in instead of hyd. fluid.
   / Color of fluid on rearend (hyd.) on 4100 #5
</font><font color="blue" class="small">( Could this be the result of 5 years of condsenation? If so is there possibly a synthetic fluid I should consider replacing it with?
Dan )</font>
WOW 5 YEARS? /forums/images/graemlins/shocked.gif
Like Pete said, the red fluid is used at the factory on the Yanmar produced tractors, so you probably have the origanal fluid in there.
How many hours are on this machine?
I would change that fluid and hydro filter ASAP, I use the JD branded fluid in mine, so cannot comment on a synthetic product
184 hours---Almost has to be water, antifreeze is nowhere near the hyd. fluid.
   / Color of fluid on rearend (hyd.) on 4100 #7
Re: Color of fluid on rearend (hyd.) on 4100 *DELETED*
OK /forums/images/graemlins/wink.gif
Post deleted by beenthere
BEENTHERE----I edited my post to remeove confusion, no we are talking tranny on a gear model.
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
434669 (A48836)
434669 (A48836)
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
