Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C?
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #61
Egan, I'm not sure if your definition of a block heater is the same as mine, but what I know as a block heater has NO thermostat (nor any other method of interrupting the current) in it. It is a straight, direct circuit as soon as it's plugged in, and keeps on heating until unplugged. Same with lower hose heaters.
Tank heaters, on the other hand, sometimes have a thermostat within them.
And while we are on the subject of cold starting, the first place to look to make it easier to start is to reduce the friction of the piston rings against the cylinder wall! Yes, it helps some to heat the crankshaft, oil pan, transmission, etc. but the biggest draw on your starter is thick oil on the cylinder walls, which a block heater reduces.
Watt for watt, put the heat on the cylinder walls first, with a block heater.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #62
Back when I worked on medium duty trucks, about the only heater we would install were the Kat's tank heaters that had pumps. They would go in the heater hose and would circulate heat through the block and heater core. One customer had a fleet of propane delivery trucks that demanded a bit more effort to get them running when very cold.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #63
My tractor also has a de-stroking capability for the hydraulic pump which will reduce the load on the crank when starting. A handy feature if starting cold in the field. Not sure if that is standard on most.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #64
The block heaters work the same as a self regulating heat tape.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #65
All the block heaters that I have installed are just pure resistive heating elements,
no control whats so ever. Easiest way to ruin one is run it with no water surrounding it.
Less then 5 minutes to element burnout.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #66
My Massey brand block heater on gc2400 don't.
There is no thermostatic shut off. And where my cooling system is relatively small I cannot just leave plugged in.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #67
I use both a both a block heater and a battery blanket. My tractor will start at the temps your stating every time with no problems. Battery blankets don't cost that much and they work.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #68
My 584IH has some sort of fuel limiting on the injection pump that aids cold starting,,
Instead of moving the fuel shut-off to the run position, the lever is only moved 25% of the way to run,,
Crank the engine,, and you get a black, thick, choking exhaust coming out of the engine,,
30 seconds of that,, and the engine is warm enough to run in the normal fuel shut-off lever position.
Maybe the fuel injection timing is changed?? I do not know,,,
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #69
Direct injection diesel has no pre combustion chamber. Indirect injection engines can make use of a glow plug. Intake manifold heating is different than an in combustion cylinder glow plug.
For our purposes lets ignore pre-combustion chamber engines, which is old technology and not used much these days, and as I stated, intake manifold heaters are often referred to as glowplugs, even though that's not the proper term.
From Wikipedia; https://en.wikipedia.org/wiki/Glowplug
A glowplug (alternatively spelled as glow plug or glow-plug) is a heating device used to aid in starting diesel engines. In cold weather, high-speed diesel engines can be difficult to start because the mass of the cylinder block and cylinder head absorb the heat of compression, preventing ignition. Pre-chambered engines use small glowplugs inside the pre-chambers.
Direct-injected engines have these glowplugs in the combustion chamber.
The glowplug is a pencil-shaped piece of metal with a heating element at the tip. This heating element, when electrified, heats due to its electrical resistance and begins to emit light in the visible spectrum, hence the term glowplug. The visual effect is similar to the heating element in a toaster. The fuel injector spray pattern then impinges directly upon the hot tip of the glow plug during the injection of fuel at top dead center. This ignites the fuel even when the engine is insufficiently hot for normal operation, which reduces the cranking time required to start the engine.
I suspect this is more likely why motors turn over easier with a block heater, since the coolant surrounds and warms the cylinders. Again, there is no coolant near the oil, the oil must be warmed another way.
The only block heater thermostat I was able to find was on some GM and Ford vehicles, which would only permit operation below a certain temp, not to shut it off at a certain temp. Can you direct us to that other type?
This is an interesting conversation and I'd like to see research done on whether a block heater warms the oil. I will be surprised, but admit it if I'm wrong. 2 similar motors 1 with block heater 1 without, with temp sensors in multiple places, oil pan, rods and crank, pistons, and inside cylinders, just to see how much heat transfers, and where it goes, from the coolant with a block heater. The only way a block heater would heat the oil is if you're running an oil cooler, and I think it would take an immense amount of heat to make a difference there.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #70
I may also change the oil to a 10-40 instead of a 15-40. The tractor is in a barn, but it is not heated.
I strongly recommend changing your oil to at least a 5w40 if not 0w40. Your battery will turn it over much easier and the engine will thank you it.
City of Lakeland (A51691)
City of Lakeland...
2013 Dodge Durango Crew AWD SUV (A55853)
2013 Dodge Durango...
2020 DRAGON ROLL OFF TRAILER (A55745)
2020 DRAGON ROLL...
DETROIT DIESEL ONE BOX (A55745)
DETROIT DIESEL ONE...
2018 KENWORTH T880 (A55745)
2018 KENWORTH T880...
