Cold weather problems NH TC-29
   / Cold weather problems NH TC-29
I think it's all resolved now. The temperature finally got above 32 for the last couple of days; that helped.
For the problem of the dead hydraulics: I had tried to heat the oil by forcing it through the relief valve. Only did it for a few moments because of the extreme noise it produced. The next time I started it is when I noticed the unresponsive hydraulics. I took the relief valve out to see if it was stuck open. It didn't appear to be stuck and was clean, but when I reinstalled it I got the functions back. With the weather a bit warmer, I was able to get smooth operation as the oil warmed up.
Next step was to change the filter. Since I already bought new oil (Case Hy-Tran), I also changed that too. I haven't found a way to do a crackle test on the oil yet but will save a sample to try later. The not-so-old oil didn't really look milky but definitely dark/cloudy. I used to have a Ford NAA and indeed water would get down around the shift boot so I know what frozen solid and milky oil is. I could let it settle to see if it clears but instead will donate it my diesel mechanic for his shop heater in return for his advice.
   / Cold weather problems NH TC-29 #12
I put some cardboard in front of the oil cooler in cold weather so that the hyd fluid will warm up. Work great, and I think that helps get rid of moisture.
I'm not aware that I have an oil cooler. Is that only on the hydrostatic drive models?
I do have a block heater which makes a huge difference for the engine starting in cold weather.
Unfortunately, my TC-29 (gear model) sits outside most of the year and only finds room in the barn during the winter. I think it's time to build a shelter for the rest of the year. In my opinion, it's the temperature swings which contribute to condensation more that getting rained on. Either way, a shelter should help.
   / Cold weather problems NH TC-29 #14
Mine is a hydrostatic and it has an oil cooler in front of the radiator. I also put a piece of cardboard that partially blocks the radiator. Never had a problem with overheating, I can plow snow for hours using the FEL and the hydraulic hoses feel warm to the touch but by no means are they overly hot.
2012 Peterbilt 337 Fluid Management Truck, VIN # 2NP2HN7X7CM159860 (A54865)
2012 Peterbilt 337...
2007 OSHKOSH FRONT DISCHARGE CONCRETE TRUCK (A54313)
2007 OSHKOSH FRONT...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A55852)
2016 Autocar...
2003 McCormick XTX 185 XtraSpeed Tractor (A55218)
2003 McCormick XTX...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
