Cold Weather On Hydraulic System
/ Cold Weather On Hydraulic System #1
Cabinholler
Central Kentucky
On 02/18/05, I bought a new 4341.1 Zetor tractor, with cab, with 4X4, with shuttle, and with a 102SL loader. How cold of weather can I use the tractor and loader, without damaging the hydraulics on the tractor and loader? I have heard some people say that using a tractor and loader in real cold weather is not good for the hydraulics. If this is true, what cold temperature reading should a person stop using their tractor and loader.
A reply to this message would be most appreciated. Thanks!
Cabinholler
/ Cold Weather On Hydraulic System #2
Where I am we use all equipment (tractors, loaders, backhoes, pickers etc) anytime we want in any weather. Make sure the engine is up to operating temperature and go to it. Trouble seems to start at -30 to -40 and it is usually from broken hoses. Check your manual.
/ Cold Weather On Hydraulic System #3
In temps below zero, I've noticed that Kubota's have the nasty habit of having the joystick freeze up. Although where I live, it doesn't stay below zero much, it is somewhat inconvenient when I can't get the loader bucket off of the ground. /forums/images/graemlins/frown.gif
I don't know if other tractors do that or not. I've mostly owned JD products in the past, and I don't recall having that happen with them. In all fairness though, I'm not sure that I had the misfortune of leaving one of the JD's outside in sub-zero weather though.
/ Cold Weather On Hydraulic System #4
That sounds more like an issue of moisture in the actual handle mechanics of the valve, not the hydraulics. The boot on the handle may not be sealing tight enough or has a crack or hole.
The performance of hydraulics in the cold is almost exclusively dependent upon the specific fluid you have in the system. There are 2 quick ways to find the proper fluid. First if you know the pump's recomended max fluid viscosity at start-up you can pick the fluid based on it's viscosity at your lowest operating temperature. The other, less precise way, is to use the fluid's pour point as the basis. As a general rule you want your pour point to be about 20degF below your lowest operating temp. So if you want to operate at 0degF, run a fluid with a pour point of -20degF or lower.
Your tractor's manual may also specify the viscosity grade necessary for various operating temps. Hope this helps.
/ Cold Weather On Hydraulic System #5
If a tractor could not be used in sub zero weather it would be worthless to have....The best thing you could do is start it up and let it idle for about 15 to 20 minutes and then get on it and use it....Thats just my 2 cents. /forums/images/graemlins/laugh.gif
/ Cold Weather On Hydraulic System #6
You will never have to worry about it being too cold where yor are from. Kentucky, right. -20 ain't nothing for a tractor.
/ Cold Weather On Hydraulic System #7
The winter of 1977 In Latonia Ky it was -25 with a wind chill of -63, granted it isn't that cold every winter but, sometimes We do have cold weather. /forums/images/graemlins/grin.gif
/ Cold Weather On Hydraulic System #8
In Artic conditions they do use fluid heaters to keep the flow. You will be ok as long as you warm up your tractor before u put a load on. In anchorage they use loaders year round. They haul the snow out of town in the winter...... Just bring ur unit up to operating temp.... I see you went with the Zetor... I am a little jealous of the cab and all. Good luck with it...
/ Cold Weather On Hydraulic System #9
</font><font color="blue" class="small">( <font color="blue"> The winter of 1977 </font> )</font>
That was definately the one for the record books.
/ Cold Weather On Hydraulic System #10
yep that was , the reason I remember that night so vividly is because I was out in it all night long. /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/frown.gif
thegreatrandini
Thank you for your input on my post about Cold Weather On Hydraulic System. Looks like I will not have to worry about my hydraulics freezing up, or being damaged here in Kentucky by from all the post from up north on this issue LOL. One post said that a tractor and loader could be operated in temperatures at a -20 degrees, and would not hurt the hydraulic system, as long as the tractor was warmed up before using it.
thegreatrandini I went with a new 4341.1 Zetor tractor, with cab, with 4X4, with shuttle, and with a 102SL loader. The reason I bought the Zetor tractor and loader is that the first time I saw it, I liked it. It also has a very large cab on it for a 55 PTO horsepower tractor that I really liked. Also, the cab is large enough for a instructional seat that I bought and installed myself. The main thing that I really liked about the Zetor tractor and loader was the price. I checked a lot of different brands of tractors with loaders, and none of the other tractor brand dealers could come near the price that I paid for the 4341.1 Zetor tractor with 102SL loader. I saved $5,000.00 on this Zetor tractor and loader compared to the other brands of tractors and loaders that I checked on. Although, I did find one tractor brand with loader that was a little less than I paid for the Zetor tractor and loader. The tractor brand that I found for a little less than the Zetor was a Foton tractor. After I looked the Foton tractor over, I liked the Zetor tractor much better. It was just a more nice looking tractor overall. The Foton tractor cab was nothing near what the Zetor tractor cab is. The Zetor tractor with cabs will be hard to beat for the price compared to other brands of tractors. So far, I like this Zetor tractor with cab a lot. At the present time, I just have a few hours on the tractor. I am still learning things about the tractor and loader, and I also am learning things from people here on the board about my new Zetor tractor and loader.
Cabinholler
/ Cold Weather On Hydraulic System #12
Be sure to warm the tractor up before using it in extreme cold and investigate if there are auxiliary heaters available. I've got a transmission heater on mine and it really makes a difference in cold weather performance. Also check the viscosity of the hydraulic oil and if there are cold weather alternatives available
DYNAPAC CA262D 84' SMOOTH DRUM ROLLER (A63290)
DYNAPAC CA262D 84'...
207270 (A52708)
207270 (A52708)
2013 ISUZU NQR 4X2 REFRIGERATED BOX (A59910)
2013 ISUZU NQR 4X2...
208735 (A60430)
208735 (A60430)
FRONTIER LP2196 - 9' GRADER BOX (A63290)
FRONTIER LP2196 -...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
