cold weather hst filter for my tc45da
   / cold weather hst filter for my tc45da #1
flyingj
Palmer Alaska
2007 NH TC45Da
I'm getting ready to do the first 50 hr on my TC45DA. I know I'm supposed to change the oil, hydraulic and HST filters. My question: The owners manual says "An optional cold weather HST filter is available. Part #SBA240500980. This filter is recommend for operation in temperatures at or below 0 degrees F (-18 C)." I plan to use my tractor a lot this winter to plow and snowblow my driveway. Does anyone know how important it is to use the cold weather filter? If I put in this filter, will it be ok for summers in Alaska? It rarely gets to be 75F in my area but it gets below zero sometimes for weeks at a time, and ocassionally as low as -25.
Thanks,
Jim Frisby
   / cold weather hst filter for my tc45da #2
If I lived in your climate, I would use that filter year-round. In extreme cold, you may have filter failures using the standard filter. However the current version of the standard filter is of better design and construction than the prior version.
2017 FREIGHTLINER TANDEM AXLE DUMP TRUCK (A54607)
2017 FREIGHTLINER...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
Ford Pickup NR (A50323)
Ford Pickup NR...
