Cold starting a PT422
/ Cold starting a PT422
Fired up the loader today without doing anything. It was about 30 degrees out and it started perfectly. I was very happy to see that.
/ Cold starting a PT422 #23
16 degrees in my pole barn. PT-422 with new 25hp Kohler fired right up - no hesitation, no pre warming. Choke and turned key. That's the way they all should start!
/ Cold starting a PT422 #24
Now you are just being cruel to us Robin folks. Come on, rub it in a bit more. :D
/ Cold starting a PT422 #25
Way to go Frank :thumbsup:
/ Cold starting a PT422 #26
Did you ever put that Amsoil in it?
Not yet. Probably going to wait until it's first oil change is due.
/ Cold starting a PT422 #28
An interesting tid bit I learned at the John Deere Dealership the other day, was that when oiling pivot points on cylinder ends and things, conventional oil works better than synthetic, because the synthetic travels more as where the minerals in conventional help it to stay at the joint. This guy seemed to know what minerals were in the different lubricants. In his opinion, since Chain and Cable Lube might work the best for those type of pivot points, because they have graphite and travel far in its initial stage by foaming up, getting back into tight areas, then the lube stays. Because it has the graphite, even when it tends to get dry, it will still lubricate. A Steiner tractor I bought new said to use Chain Lube in the owners manual, which it seems they knew what they were talking about.
/ Cold starting a PT422 #29
Interesting info about lubrication of cylinder ends.
I've been using lithium wheel bearing grease dissolved in old gasoline. Paint it on with a chip brush. It seems to migrate well then dries and leave a grease residue. I particularly like this because it's so easy to do and very inexpensive, so i do it with regularity.
I don't recall, but im pretty sure i learned the grease gas thing from somebody here on TBN, specifically the Power-Trac forum.
/ Cold starting a PT422 #30
If you do a little searching in this forum you will find a lot of discussion of the poor cold weather performance of the robin engine. It doesn't help that while you are trying to start it, the starter motor also has to deal with spinning the oil pumps with cold oil in them.
suggestions:
1. keep it in the garage (this, however, won't solve the problem, just help)
2. put a magnetic heater on the oil tank
3. put a space heater behind it blowing into the engine compartment for half an hour before you want to start it
Assuming that the engine turns over fast enough, and that the fuel isn't gelling, the issue with starting diesels is getting heat into them. Figure out how to get warm or hot air into the intake. A heat gun running on a generator for 15 minutes and then turn the engine over with the heat gun blowing hot air into the intake.
Other wise with 120v, block heaters, hydro heaters, and fuel heaters.
/ Cold starting a PT422 #31
Thats interesting and makes sense.
/ Cold starting a PT422 #32
Awesome video!
This year I got sick of fighting the cold and I have seemed to find a solution that works so far. We now keep a generator on the trailer that we haul the loader with. We plug in a battery charger that has a jump start function to the generator and hook it up to the battery. That works great! For colder days I bought a propane torpedo heater. It's just a small one, but I aim that at the air intake and let it go for a few minutes. Again, that seems to work wonders. All and all, I bet it takes us a half hour of messing around to get it stated. That's fine with me because we usually have some time at the beginning of our job where we're getting set up on other things as well. It's just part of our routine now. I feel a lot better just knowing that we will get it started.
/ Cold starting a PT422 #34
I recently installed the Kat's heater pad on the hydraulic tank. This thing gets HOT!!
Wish I had done this winters ago! Was around 20 degrees the first time I started it and was an instant start after running the small battery charger for a few hours.
We have one of Kat's magnetic heaters for the hydros too. It does get hot but I'm not sure how much good it does. It's just too small to make a significant difference.
/ Cold starting a PT422 #36
Before I swapped out my Robin for a Kohler, The first two years I had the machine I had 2 KAT magnetic heaters. They were pretty much useless. When Terry told about the silicone pad I was very skeptical but also desperate. So I bought one and installed it just like Terry said to do. It was 100% better than the magnetic heaters and the propane torpedo heaters etc... I have still have the silicone heater attached to my 422, but never have had to use it since putting in the Kohler. If you are not planning on swapping out your robin for a Kohler in the near future - the silicone pad is the way to go for cold starts
Any chance you could post of pictures of your set up?
/ Cold starting a PT422 #38
Started my 2001 PT425 with the Kohler at 4 degrees F this morning. Fired up pretty good. :thumbsup:
/ Cold starting a PT422 #39
I used 3 of the magnetic heaters when storing the tractor in unheated space. They definitely helped but not a great solution. The glow plugs (intake manifold heaters) worked as well or better than the magnets down to 20° F.
Ken
2007 FREIGHTLINER M2 4X2 S/A STAKE BED TRUCK (A59910)
2007 FREIGHTLINER...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
