Cold Start
/ Cold Start #1
stampede38899
North Carolina
Tiashan Dragon 270
I have a Taishan Dragon 270 Diesel tractor. I was wandering if these tractors had glow plugs or what? The tractor does have a compression release onit. I had to replace the ignition switch with a switch from a Ford tractor. I wired it to what I beleive was correct. I just want someone else opinion who knows these tractors.
/ Cold Start #2
Well if it does, they will most likley be located in the vicinity of where the intake manifold attaches to the head. Look for a piece threaded into the head or manifold in close proximity to each intake port. The studs on top may be tied together by a single metal bussbar with a wire attached to that buss. Not specifically familliar with your tractor, but I know from reading a few versions of the jinma's had them installed, but the wiring was never connected.
If the switch you installed has a preheat position(the position reached just before the starter is engaged), when you turn the key to this position, you will note a large negative amp gauge deflection if you have glowplugs installed and wired.
/ Cold Start #3
Didn't we at one time conclude that you had an intake heater? I thought you were in the process of seeing if it actually worked. Or have I mixed this TaiShan up with some one else?
//greg//
John Deere 5525 (A60462)
John Deere 5525...
2004 John Deere 7820 (A60462)
2004 John Deere...
Dodge Ram 8ft. Pick up Bed (A60352)
Dodge Ram 8ft...
Mini excavator set attachment (A61567)
Mini excavator set...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
