Cold start problem
   / Cold start problem #1
BeezFun
Veteran Member
IL
Kubota B2710
I have a commercial Toro ZTR, never had a bit of trouble but it's always been really hard to start when cold and it's getting worse. It has a 25hp kawasaki FH721D engine. Over a few years I've replaced plugs, wires, and fuel pump (it was leaking slightly). It's started hard since it was new but never made it back to the dealer when it was under warranty because it wasn't as bad. It doesn't matter much what the temp outside is, it starts very hard even when it's 90 degrees out. Starts great once it's been run for a few minutes.
tnx
   / Cold start problem #2
i'd go with a weak coil. check that out.
Can I measure resistance on primary and secondary side to identify weak coil, or do I need to take it someplace that can test it?
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
NEW HOLLAND C362 SKID STEER (A52705)
NEW HOLLAND C362...
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
