- Joined
- Sep 6, 2011
- Messages
- 6,213
- Location
- Philadelphia
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Cool. Which manual grinder?
I picked up a KINGrinder K2 awhile back, when my Sette 270 espresso grinder broke down, as I knew repair parts would take a few weeks. It was fun to use it for a few days, but then became a bit of a grind (sorry... pun), after the novelty wore off. If I were only using it on weekends, it'd be fine, my recommendation for a good burr grinder was more about the daily grind.
Most of these older burr grinder designs have a hopper and a timer, so you can just adjust the time to produce the amount of ground coffee you require. But because they're always horribly inaccurate (grind rate changes with coarseness, with bean type, with bean roast level, and even with number of days since roasting), most stopped using the hopper and timer. Just measure out the amount of beans you want to grind, put it all in the hopper, and run it thru.
Many newer grinder designs seem to be following this "single dosing" mentality, and have eliminated the hopper and timer altogether. But there's something to be said for trusting the durability of older designs that have been battle tested over many years. If I'm spending money on a good burr grinder, I want the damn thing to last me 20 years.
One other note, look at coffee forums about warranty service. The reason all of my grinders have been from Baratza, is their warranty service is historically second to none. My Sette 270 has failed twice, using it 3-4x per day for something like 6 years. Both times, Baratza sent me the repair parts totally free of charge, no questions asked, even though the machine is many years past the warranty period. In one case, that was a whole new gear box and burr assembly, after 5.5 years of daily use, now basically all the moving parts in the grinder are new. Now that Baratza has been bought by Breville, I worry that could change a bit, but so far it has not.
