Code 81, TN 70A, power shutttle problem
   / Code 81, TN 70A, power shutttle problem #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
Dealer has requested NH Assist on a code 81. Says the tranny is fine, but cannot clear the code 81 from the computer, which prevents tranny from working.
Any ideas?
Bob
Any ideas?
Bob
   / Code 81, TN 70A, power shutttle problem #3
There was a previous discussion on this back in Feb. Not sure if you saw it - Do a search on code 81
   / Code 81, TN 70A, power shutttle problem #4
I did a search on code 81 and only posting was on camcorders.
Bob
Bob
   / Code 81, TN 70A, power shutttle problem #7
You will most likely have a faulty Charge Pressure Switch (part#82031395). It is located on the left hand side of the tractor and is accessible fairly easily. Your dealer should be able to supply you with one and giv eyou additional info. Good Luck......tractorman
   / Code 81, TN 70A, power shutttle problem #8
</font><font color="blue" class="small">( You will most likely have a faulty Charge Pressure Switch (part#82031395). It is located on the left hand side of the tractor and is accessible fairly easily. Your dealer should be able to supply you with one and giv eyou additional info. Good Luck......tractorman )</font>
Thanks!
Bob
Thanks!
Bob
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2016 VOLVO EC380EL EXCAVATOR (A51246)
2016 VOLVO EC380EL...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
