Code 81, TN 70A, power shutttle problem
   / Code 81, TN 70A, power shutttle problem #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
Dealer has requested NH Assist on a code 81. Says the tranny is fine, but cannot clear the code 81 from the computer, which prevents tranny from working.
Any ideas?
Bob
Any ideas?
Bob
   / Code 81, TN 70A, power shutttle problem #3
There was a previous discussion on this back in Feb. Not sure if you saw it - Do a search on code 81
   / Code 81, TN 70A, power shutttle problem #4
I did a search on code 81 and only posting was on camcorders.
Bob
Bob
   / Code 81, TN 70A, power shutttle problem #7
You will most likely have a faulty Charge Pressure Switch (part#82031395). It is located on the left hand side of the tractor and is accessible fairly easily. Your dealer should be able to supply you with one and giv eyou additional info. Good Luck......tractorman
   / Code 81, TN 70A, power shutttle problem #8
</font><font color="blue" class="small">( You will most likely have a faulty Charge Pressure Switch (part#82031395). It is located on the left hand side of the tractor and is accessible fairly easily. Your dealer should be able to supply you with one and giv eyou additional info. Good Luck......tractorman )</font>
Thanks!
Bob
Thanks!
Bob
2020 Kinze 3505 High Speed 6/11 Planter (A53472)
2020 Kinze 3505...
1989 Chevrolet Corvette Passenger Car, VIN # 1G1YY318XK5111655 (A51572)
1989 Chevrolet...
2016 CATERPILLAR 277D SKID STEER (A51246)
2016 CATERPILLAR...
20 Yard Rolloff Container (A51573)
20 Yard Rolloff...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
