LittleBill21
Elite Member
TheMan419 -
Glad to see you got positive results just moving the antenna outside for your test run. Definitely take your time tweaking the antenna; we use that antenna all the time & tiny adjustments make big differences. Granted we are 99% of the time using the antenna with a booster & internal antennas, & we also own testing equipment to help in aiming; but the antenna alone can give a 7 - 8+ dBi Gain by itself if tuned in.
I don't think you want to add the second antenna to the MoFi's other antenna connection; if I'm not mistaken it only has two... So if you are using the MoFi as your WiFi access point also, I believe you would be seriously depleting it, as the attached antennas are also used to distribute the signal inside. (I'm thinking, even using the first one for the outdoor wideband antenna will have some effect, but the increase in signal is probably worth it for you.)
As I mentioned our systems are usually designed to boost & redistribute the cellular signal through out a space helping both voice & data devices, we don't normally connect directly a router. (so I could be wrong)... Now if you are not using the MoFi as your WiFi access point then it might be ok...
If you want to use a second external Wideband antenna you might want to look at using a Diplexer / Combiner which will allow you to connect two antennas out at the pole (your mounting point), aim them in different directions & combine their signals on the same coax going back to your MoFi. I've never done this for the same signal / Carrier, we do this for different carriers that are on different towers but need to provide multi-carrier distribution within a building. I believe the correct Wilson Diplexer / Combiner part # is 859922:
Wilson Cell Phone Signal Boosters | Cell Boosters | WilsonPro
I would also recommend an inline sure suppressor for this type of installation....
which cell amp do you generally use? the wilson product line?
