Co-op E3 pto
/ Co-op E3 pto #1
remchuk
case ih 245
Gonna check out an old Co-op. At first check it's sound, but I found the pto had some slop. Any one know if this is a straight forward bearing replacement or do I have to completely tear down the rear end?
Thanks
/ Co-op E3 pto #2
The E-3 is like a Cockshutt 30. Researching that might get you more info.
I grew up running a Cockshutt 20 and owned a 40(like a E-4). The 20 was completely different but I believe the 30 and 40 could have been similar. I recall seeing two distinctly different shaped PTO units that came on both the 30 and 40 but they were always a external unit that bolted to the tractor.
All the problems that I saw with those PTO units were within the unit itself. They are a live PTO which means it has a clutch pack that does wear out.
Oliver took over and I believe used at least some of that design. Another avenue for you to follow.
2008 Ford F-250 Pickup Truck (A61573)
2008 Ford F-250...
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
2010 Chevrolet HHR SUV (A61574)
2010 Chevrolet HHR...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
Adams Nurse Trailer Tank (A63688)
Adams Nurse...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
