Co-op E3 pto
/ Co-op E3 pto #1
remchuk
case ih 245
Gonna check out an old Co-op. At first check it's sound, but I found the pto had some slop. Any one know if this is a straight forward bearing replacement or do I have to completely tear down the rear end?
/ Co-op E3 pto #2
The E-3 is like a Cockshutt 30. Researching that might get you more info.
I grew up running a Cockshutt 20 and owned a 40(like a E-4). The 20 was completely different but I believe the 30 and 40 could have been similar. I recall seeing two distinctly different shaped PTO units that came on both the 30 and 40 but they were always a external unit that bolted to the tractor.
All the problems that I saw with those PTO units were within the unit itself. They are a live PTO which means it has a clutch pack that does wear out.
Oliver took over and I believe used at least some of that design. Another avenue for you to follow.
2020 McCloskey R155 Trommel Screener (A61572)
2020 McCloskey...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2014 GENIE S-40 TELESCOPIC BOOM LIFT (A64279)
2014 GENIE S-40...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
Jacobsen LF510 5 Gang 100in. Commercial Reel Mower (A61572)
Jacobsen LF510 5...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
