CM224 vibration
/ CM224 vibration #1
jav37
Heath, Ohio
Oliver 77, Ford 8N, Kubota b6200, Kubota L4200, New Holland CM22, New Holland CM222
I recently purchased a New Holland 2001 CM224 Mower. The pulley on the PTO shaft was loose and I tightened it and placed a rubber washer to keep it tighter. The problem is there is a vibration in the PTO to the engine system that makes noise and will stop and or start if you play with the throttle up and back. I cannot find the source of the noise. I have placed a wooden stick on the PTO shaft pulley, The flywheel, the intermediate shaft between the engine and the transmission and I cannot stop the issue. Is there a common bearing or shaft or ??? that wears and causes the vibration? The PTO can be engaged or not and still have the vibration.
Thanks for any help with this.
Joe
/ CM224 vibration #3
Jav37 have you found any information about your vibration issue I just purchased a more and having same issue leave it just needs bearing changed wasn't sure how to get the shaft out though
Landhonor Livestock Chute w/ Scale (A66408)
Landhonor...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
3 Point Hitch Cultivator (A65579)
3 Point Hitch...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2022 EZ-GO ELITE...
72in. Skid Steer Bucket (A65640)
72in. Skid Steer...
