Clutch
/ Clutch #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
What is a single clutch vs. a dual stage clutch?
/ Clutch #2
A dual stage (if it's like mine) will disengage the drive when you push it half way down, then disengage the pto when you push it all of the way down.
/ Clutch
When I shuttle from reverse to forward, can I get away with stepping on the clutch half way?
/ Clutch
My ck35 does have the two stage clutch. Pressing down on it, I can feel the first then second positions. I'm having knee problems, and if I can get away with just a partial step down, it would be a blessing.
The first stage is light, the second stage is tough on the knee. Anybody out there just partially press down when taking off in gear or shuttle shifting from reverse to forward?
/ Clutch
I just got in from a test-run. Very light pressure on the clutch, and it works. No grinding or anything. I hope the drive clutch is disengaging all the way with the partial step down. Big difference on my bum knee.
/ Clutch #7
That's kind of the purpose of having 2 stages. For tasks such as mowing you change speed and/or direction without disengaging the mower.
2011 Ford F250 Super Duty Lariat (A66408)
2011 Ford F250...
Grizzly Bear Statue (A65583)
Grizzly Bear...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2012 Allmand Nite-Lite Pro II 8KW Towable Light Tower (A64194)
2012 Allmand...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
